Re: GROUND WIRE QUESTION....................
[Re: CHAPPER]
#1372379
01/22/13 10:40 PM
01/22/13 10:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I know service trucks use the frame for a ground and there is always something malfunctioning and it is 90% of the time ground related. So I am not going to criticize anyone for running grounds on a race car. Just their reasoning. LOL
Leon
Big trucks the frame is rivided together which under stress/load and time come loose creating a bad ground joint so yes thats not good
Don't forget all the fiberglass/aluminum cab, fenders, bunks, etc. I imagine that is more of the problem than the riVited frame.
Well you know damn well they dont ground to the fiberglass and they dont like the alum either... specially that the body is basically floating on the chassis... they do have jumper grounds going to the chassis
[Re: emarine01]
#1372384
01/24/13 10:04 PM
01/24/13 10:04 PM
Posts: 9,863 MI, usa
dvw
MI, usa
I thought the secondary contacts were used to brake the field circuit?
They will be now. I only have a one wire alternator so I couldn't break the field. Doug
[Re: Scott58]
#1372387
01/25/13 09:44 PM
01/25/13 09:44 PM
dvw
MI, usa
You might consider the Longacre 45782. Secondary contacts rated at 125A.
Scott
I did look at that. I'm going to run a solenoid at the alternator output and use my 2.0 feed from the battery to charge. If that has voltage drop I'm in trouble. Doug
[Re: dvw]
#1372388
01/25/13 11:00 PM
01/25/13 11:00 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Scott
I know it has been done this way and some people get away with it but there is a potential drawback. The alternator is a HIGHLY inductive circuit and if you just disconnect the output with a solenoid or any other means you can get potentially VERY high voltage spikes. This is also a potential problem with just about any other method that doesn't connect the alternator output to the battery side of the master kill switch. Even the field circuit can generate spikes if there isn't enough electrical load on the same circuit. In the OE configuration the alternator output is always connected to the battery and the field circuit shares a power feed with the ignition and some other loads. Also, the electronic regulators may provide a 'soft-landing' for the field current when the power is turned off.
On my track car I have a field circuit switch in reach of the drivers seat and I turn it off if a tech inspector wants to test my kill switch. The kill switch will work either way but this way the alternator doesn't need to find an alternate circuit for all that stored energy in the magnetic field.
Way back when I killed my memory tach with voltage spikes. The only items on the circuit were the alternator field power, voltage regulator, tachometer and some tiny gauge lights. The gauge lights would flash brightly if I killed the engine with the second master switch I have near the drivers seat. I've since redesigned the power feeds so there's more devices on the alternator field opwer and regulator circuit and I never kill the engine with either master switch, always using the ignition switch that shuts off the MSD box.
[Re: @#$%&*!]
#1372389
01/25/13 11:10 PM
01/25/13 11:10 PM
Thumperdart
State of confusion
Lots of of great info here............. Learning bits here and there since my wiring skills aren`t the best and I`m finishing up a week long wiring journey but the end results are alreadyi there as in brighter lights and less voltage drop at the battery.
[Re: @#$%&*!]
#1372390
01/25/13 11:22 PM
01/25/13 11:22 PM
dvw
MI, usa
Scott
The solenoid will be wired with the master switch. Therefore it will be energized before starting and after the engine is shut off, no spikes. Doug
