Re: Piston to Wall Clearance for 2355 "Six Pack" pistons??
[Re: RoadRunnerJD]
#1371336
01/19/13 07:22 AM
01/19/13 07:22 AM
Posts: 2,141 junction city oregon
viperblue72
They are definitely right around 875g without the pin.
I wouldn't dwell on the weight. You can find lighter pins and remove some metal under the pistons to lighten them some if you want but unless you are trying to wring that one extra tenth of a second out of it and race every weekend, the weight is not going to make that much difference. Otherwise, but lightweight pistons and rods and go all out.
I don't think horsepower is the reason for concern about the weight. I think the stress that it puts on the rest of the bottom end is imo. Although these old trw's are very prevalent and have been used for years with success.
[Re: BPBP440]
#1371337
01/19/13 12:19 PM
01/19/13 12:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since you will be talking to Best Machine, let them balance the assm... Chrysler was bad enough on a stock balance that if you want a smooth running engine I would have them balance it.. no matter if you found pistons with equal weight
[Re: viperblue72]
#1371338
01/19/13 01:25 PM
01/19/13 01:25 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
No problem for a street machine. You want to talk about weight of the reciprocating mass, what about the heavy rods in the 70-71 6-BBL cars or a 426 Hemi? I broke an LY rod in an original A12 motor once but it was at 8200 RPM's with over 200 runs on a 13.6:1 race only motor. I would not worry about the weight but I would definitely get it balanced if you are changing pistons!
[Re: B G Racing]
#1371342
01/23/13 09:06 PM
01/23/13 09:06 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
We ran into the same issue with SpeedPro and not getting a solid answer.We have seen a lot of their pistons scored at the skirt on engines that were set at .0015/.0025 for street use and many machinest would rather set it at .004/.005.
Bob - that is what I remember. The first set I bought about 25 years ago actually came from SpeedPro with the 0.0015" - 0.0025" spec in the instructions, and guys that ran them at that would tear-up the skirts. My machinist and I decided to put them in at 0.0035". I still have them (in a box now) and they look perfect. I would not think about putting them in at anything less. Of course, today's metallurgy is probably way different.
[Re: B G Racing]
#1371343
01/23/13 11:28 PM
01/23/13 11:28 PM
Posts: 264 Farmington Hills, MI
BPBP440
We ran into the same issue with SpeedPro and not getting a solid answer.We have seen a lot of their pistons scored at the skirt on engines that were set at .0015/.0025 for street use and many machinest would rather set it at .004/.005.We have set the forged hi-silicone pistons at .0025 to.0035 on race applications with synthetic oils and found no problems.
Moving forward with the Speedpro pistons. Thanks to all for the great advice.
