Page 12 of 21 1 2 10 11 12 13 14 20 21
Re: Pistons [Re: MR_P_BODY] #1370092
12/14/14 11:13 PM
12/14/14 11:13 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think the Modman suffers from piss poor fuel distribution. The runner length has the same effect as any other engine. If using EFI with an injector at every port, the fuel distribution problem is solved. Under boost, I think the runner length becomes less of a problem too.
Mopar to the bone!!!
Re: Pistons [Re: 72Swinger] #1370093
12/14/14 11:21 PM
12/14/14 11:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats good.. I will be using multi port... I wasnt sure
if it was the distribution issue... in that case I MIGHT
be making a intake.. depending on height clearances
Re: Pistons [Re: MR_P_BODY] #1370094
12/14/14 11:40 PM
12/14/14 11:40 PM
gregsdart Offline OP
One of the options I am interested in is the srt8 6.4 plastic intake. If you are going to electronic injection, the question becomes, why not go for the whole enchilada? The 6.4 intake looks to be lower than the barrel shaped 6.1, and it has variable runner length that I here could be run by an rpm switch. If you have the cubes and heads, that should then make comparable if not more hp than a stock 6.4, and with a cam and headers ought to be a real animal. The cost of the 6.4 intake manifold and attending parts is what I would like to find out. It might get spendy buying it all new. There must be some guys out there that put on a blower and are willing to sell the stock stuff.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Pistons [Re: gregsdart] #1370095
12/14/14 11:48 PM
12/14/14 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the Holley injection it will pretty much run
the engine... I'll use my throttle body and maybe
another one.. just thinking but I need enough room for
a good hat
Re: Pistons [Re: gregsdart] #1370096
12/15/14 12:15 AM
12/15/14 12:15 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I wonder about that too. I do like the possibility of running the variable runners and heat rejection of the plastic intake, and the other thing, the 6.1 intake is pretty heavy. I wonder what the plastic intake weighs?
Re: Pistons [Re: ntstlgl1970] #1370097
12/15/14 12:21 AM
12/15/14 12:21 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Wish someone would make a plastic 6.1 intake. They are heavy, although I put the time in to lighten mine quite a bit. 6.4 intakes have been swapped onto 6.1's and 5.7's both. Modern Muscle even offers CNC of the TB opening.
Re: Pistons [Re: ntstlgl1970] #1370098
12/15/14 12:24 AM
12/15/14 12:24 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
A couple of things to add to the list -
1. The TTI mounts don't mount cleanly on the aluminum block, they need to be clearanced for block bolt bosses on both sides.
2. Mix and match threads and fasteners - good old Chrysler, never changes. Can't make up their minds to go all metric or SAE. The bellhousing bolts are 3/8-16 thread, the block coolant drain plugs are 9/16 head. Everything else appears to be metric.
3. Arrow racing suggested to use the 6.4L main bearings, he said that it helps address some oiling issues (he did not elaborate)
Re: Pistons [Re: 72Swinger] #1370099
12/15/14 12:26 AM
12/15/14 12:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Will the 6.4 intake fit a 5.7
Re: Pistons [Re: MR_P_BODY] #1370100
12/15/14 12:29 AM
12/15/14 12:29 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
With Eagle,6.1 or Apache heads, yes.
Re: Pistons [Re: 72Swinger] #1370101
12/15/14 12:33 AM
12/15/14 12:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok
Re: Pistons [Re: MR_P_BODY] #1370102
12/15/14 02:18 AM
12/15/14 02:18 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I am looking at a 06 5.7 out of a Ram.. is this block
a decent starting point.. does it have the VVT.. it
is a complete engine
thanks
It won't have VVT but it will have MDS if that matters.
Kevin
Re: Pistons [Re: Cevidicus] #1370103
12/15/14 10:38 AM
12/15/14 10:38 AM
Canada
onig Offline
onig  Offline
Canada
Yes, that would work. No, it does not have vvt. Sounds like a good starting point if the price is right. Keep in mind the timing cover and accessory drive are different than on a car. You can't use the 6.1 intake without modifying the timing cover.
What mods will be necessary to the truck timing cover for the 6.1 intake to work, and any pics of this mod?
69 Dart
Re: Pistons [Re: 72Swinger] #1370104
12/15/14 11:09 AM
12/15/14 11:09 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Isn't the 5.7 car intake a plastic version of the 6.1?
Matt
Re: Pistons [Re: MattW] #1370105
12/15/14 11:31 AM
12/15/14 11:31 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I think it is but with smaller ports. The 5.7 Eagle intake seems the be the one to get, bigger ports and has the variable runners as well. One thing to watch on the 6.4 intakes is when you do a turbo or centrifigal blower on them, they have a flow imbalance when the boost gets turned up because of the curved inlet, think short turn in an intake port, it likes to hug the outside wall so the passenger side see more than the driver side, something I read on LXForums
Re: Pistons [Re: 72Swinger] #1370106
12/15/14 12:02 PM
12/15/14 12:02 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
From what I've read on LX forums is that the Eagle 5.7 intake is essentially a plastic version of the aluminum 6.1 intake.
http://www.lxforums.com/board/showthread.php/200137-FOR-SALE-Brand-New-2010-5-7-Intake-Manifold
The TA2 Challengers also use them on their race engines
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Pistons [Re: WO23Coronet] #1370107
12/15/14 12:13 PM
12/15/14 12:13 PM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
As mentioned, the 6.4 intake (for cars, I don't know about the truck variant) has an imbalance from one bank to the other, even without forced induction, and made worse with forced induction. The factory tune accounts for that for those cylinders.
The 5.7 Eagle car intake does not have the variable runner setup, the 5.7 Eagle truck intake does.
Some posts regarding it: On The Dyno, A Study Of The Effect Of Boost On The 6.4 Intake
StricNine
79 Li'l Red Express, 15.04 @ 89.57
09 Challenger R/T, 11.95 @ 115.92
Re: Pistons [Re: StricNine] #1370108
12/15/14 12:46 PM
12/15/14 12:46 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I've had a 5.7 car 05-08, 5.7 eagle car and a 6.1.
Needless to say, I've only got the 6.1 intake now and my next purchase will be a MP drag pack intake.
The plastic stuff is good, but the sleeve on the inside is a hinderance. 6.1 is the best intake for what most of use are doing and it doesn't look cheesy.
If FAST came out with a polymer intake, I'd have that with a 102mm tb and be set for life.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Pistons [Re: AlexP] #1370109
12/15/14 01:22 PM
12/15/14 01:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well I guess I have to keep looking.. that engine
fell through.. sold
Re: Pistons [Re: MR_P_BODY] #1370110
12/16/14 03:20 PM
12/16/14 03:20 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
FWI to anyone interested, the 6.4 heads are still discounted $470 plus $150 core charge
Re: Pistons [Re: sixpackgut] #1370111
12/16/14 08:37 PM
12/16/14 08:37 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Can you please post the info again on how to obtain these heads at the discounted price?
Thanks!
Mike
OST Dyno - Home of the worlds Quickest and Fastest Supercharged Hellcat!
Building and tuning record setting Gen III Hemi’s since 2006!
