Pistons
[Re: 1badx]
#1370073
11/24/14 06:37 PM
11/24/14 06:37 PM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
1Badx - This might be a more appropriate forum to get the facts sorted out on using cast pistons with FI. Can you detail your exoeriences with the factory slugs - espevially the 6,1 - and superchargers....including any thoughts you may have on using a blow thru system? I have no personnal experience - but was pretty much put off the idea when I posted on the LX forums by people saying they wouldnt last - that the top ring land would fail.. I would only be considering around 7psi at max.....so interested to hear your opinion?
Re: Pistons
[Re: hudsonhornet7x]
#1370077
11/26/14 03:35 AM
11/26/14 03:35 AM
Posts: 10,183 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Okay- I have a question for you guys-
How much naturally aspirated power will the stock pistons and rods live with in a 6.4 liter engine?
Forged crank, powdered rods, cast pistons
Just a WAG, but I could see where the piston to valve clearance issues, plus the extra strength built into stock stuff for warranty would keep you safe with all the bolt on goodies you can screw together. Headers, ported heads, manifold, tune, cam, the works. I would guess somewhere around 150 more hp. You can get a good idea by researching who is going fast with bolt on parts in the LX forums, and who is driving over some of their parts. The latter have found the limits That is how I picked the boost for my Mustang GT blower package. Most guys who stayed below about 500 hp on a 300 hp 4.6 were not having trouble. Beyond that, it is a crap shoot for that particular motor. For normally aspirated, then total rpm becomes more important (pistons/rod speed)along with oil control so you don't starve the bearings.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Pistons
[Re: 1badx]
#1370079
11/26/14 05:28 PM
11/26/14 05:28 PM
Posts: 361 Canada
onig
Canada
I just read that post. Any updates on that thread Mike? Thanks for sharing, very interesting to say the least. I feel like going to work on the 5.7 sitting on the shelf at work that came out of a Ram. Can I hit you up for some tuning tips when the time comes?
thanks Onig
69 Dart
Re: Pistons
#1370080
11/26/14 10:29 PM
11/26/14 10:29 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
About 600+ but you're limited on camshaft sizing with the stock pistons, so it's nearly impossible to make that power N/A anyway.
Re: Pistons
[Re: ntstlgl1970]
#1370082
12/01/14 12:43 AM
12/01/14 12:43 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Pretty much all of them are reusable to point. Unless the engine has a ton of miles or got really hot.
Mopar to the bone!!!
Re: Pistons
[Re: ntstlgl1970]
#1370085
12/14/14 10:35 PM
12/14/14 10:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I am looking at a 06 5.7 out of a Ram.. is this block a decent starting point.. does it have the VVT.. it is a complete engine thanks
Re: Pistons
[Re: MR_P_BODY]
#1370086
12/14/14 10:43 PM
12/14/14 10:43 PM
Posts: 72 San Angelo, Texas
Cevidicus
San Angelo, Texas
Yes, that would work. No, it does not have vvt. Sounds like a good starting point if the price is right. Keep in mind the timing cover and accessory drive are different than on a car. You can't use the 6.1 intake without modifying the timing cover.
Re: Pistons
[Re: Cevidicus]
#1370087
12/14/14 10:51 PM
12/14/14 10:51 PM
MR_P_BODY
Good enough.... also... does the car front end work on this(timing cover and accessories)
Re: Pistons
[Re: 72Swinger]
#1370089
12/14/14 10:59 PM
12/14/14 10:59 PM
MR_P_BODY
Yep timing covers interchange. But a truck cover might be what you want if you're thinking turbo's since it mounts the alt up top.
Ok... but it might be too tall to fit under the hood but at least I have options
Re: Pistons
[Re: 72Swinger]
#1370091
12/14/14 11:05 PM
12/14/14 11:05 PM
MR_P_BODY
Since you guys were talking intakes and the shorter intake tends to hurt the low end power.. was this on the carb version or injected also... might be hard to fit a tall intake on with a air cleaner and a throttle body.. or I might end up making a intake.... thoughts EDIT and later the hat and turbo would go on and loose the air cleaner
