Re: Pistons
[Re: MR_P_BODY]
#1370092
12/14/14 11:13 PM
12/14/14 11:13 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I think the Modman suffers from piss poor fuel distribution. The runner length has the same effect as any other engine. If using EFI with an injector at every port, the fuel distribution problem is solved. Under boost, I think the runner length becomes less of a problem too.
Mopar to the bone!!!
Re: Pistons
[Re: 72Swinger]
#1370093
12/14/14 11:21 PM
12/14/14 11:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats good.. I will be using multi port... I wasnt sure if it was the distribution issue... in that case I MIGHT be making a intake.. depending on height clearances
Re: Pistons
[Re: MR_P_BODY]
#1370094
12/14/14 11:40 PM
12/14/14 11:40 PM
Posts: 10,184 Frostbitefalls MN (Rocky&Bullw...
gregsdart
One of the options I am interested in is the srt8 6.4 plastic intake. If you are going to electronic injection, the question becomes, why not go for the whole enchilada? The 6.4 intake looks to be lower than the barrel shaped 6.1, and it has variable runner length that I here could be run by an rpm switch. If you have the cubes and heads, that should then make comparable if not more hp than a stock 6.4, and with a cam and headers ought to be a real animal. The cost of the 6.4 intake manifold and attending parts is what I would like to find out. It might get spendy buying it all new. There must be some guys out there that put on a blower and are willing to sell the stock stuff.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Pistons
[Re: gregsdart]
#1370095
12/14/14 11:48 PM
12/14/14 11:48 PM
MR_P_BODY
With the Holley injection it will pretty much run the engine... I'll use my throttle body and maybe another one.. just thinking but I need enough room for a good hat
Re: Pistons
[Re: ntstlgl1970]
#1370097
12/15/14 12:21 AM
12/15/14 12:21 AM
72Swinger
Nebraska
Wish someone would make a plastic 6.1 intake. They are heavy, although I put the time in to lighten mine quite a bit. 6.4 intakes have been swapped onto 6.1's and 5.7's both. Modern Muscle even offers CNC of the TB opening.
Re: Pistons
[Re: ntstlgl1970]
#1370098
12/15/14 12:24 AM
12/15/14 12:24 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
A couple of things to add to the list -
1. The TTI mounts don't mount cleanly on the aluminum block, they need to be clearanced for block bolt bosses on both sides.
2. Mix and match threads and fasteners - good old Chrysler, never changes. Can't make up their minds to go all metric or SAE. The bellhousing bolts are 3/8-16 thread, the block coolant drain plugs are 9/16 head. Everything else appears to be metric.
3. Arrow racing suggested to use the 6.4L main bearings, he said that it helps address some oiling issues (he did not elaborate)
Re: Pistons
[Re: 72Swinger]
#1370099
12/15/14 12:26 AM
12/15/14 12:26 AM
MR_P_BODY
Will the 6.4 intake fit a 5.7
Re: Pistons
[Re: 72Swinger]
#1370101
12/15/14 12:33 AM
12/15/14 12:33 AM
MR_P_BODY
With Eagle,6.1 or Apache heads, yes.
Ok
Re: Pistons
[Re: MR_P_BODY]
#1370102
12/15/14 02:18 AM
12/15/14 02:18 AM
Posts: 6,672 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I am looking at a 06 5.7 out of a Ram.. is this block a decent starting point.. does it have the VVT.. it is a complete engine thanks
It won't have VVT but it will have MDS if that matters.
Kevin
Re: Pistons
[Re: Cevidicus]
#1370103
12/15/14 10:38 AM
12/15/14 10:38 AM
Posts: 361 Canada
onig
Canada
Yes, that would work. No, it does not have vvt. Sounds like a good starting point if the price is right. Keep in mind the timing cover and accessory drive are different than on a car. You can't use the 6.1 intake without modifying the timing cover.
What mods will be necessary to the truck timing cover for the 6.1 intake to work, and any pics of this mod?
69 Dart
Re: Pistons
[Re: 72Swinger]
#1370104
12/15/14 11:09 AM
12/15/14 11:09 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Isn't the 5.7 car intake a plastic version of the 6.1? Matt
Re: Pistons
[Re: WO23Coronet]
#1370107
12/15/14 12:13 PM
12/15/14 12:13 PM
Posts: 154 Plano, TX
StricNine
Plano, TX
As mentioned, the 6.4 intake (for cars, I don't know about the truck variant) has an imbalance from one bank to the other, even without forced induction, and made worse with forced induction. The factory tune accounts for that for those cylinders. The 5.7 Eagle car intake does not have the variable runner setup, the 5.7 Eagle truck intake does. Some posts regarding it: On The Dyno, A Study Of The Effect Of Boost On The 6.4 Intake
StricNine
79 Li'l Red Express, 15.04 @ 89.57 09 Challenger R/T, 11.95 @ 115.92
Re: Pistons
[Re: MR_P_BODY]
#1370110
12/16/14 03:20 PM
12/16/14 03:20 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
FWI to anyone interested, the 6.4 heads are still discounted $470 plus $150 core charge
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
