Re: Gen III Hemi, please post things to avoid,,,,,,,,,
[Re: RylisPro]
#1370052
11/04/14 02:03 PM
11/04/14 02:03 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
What about a front motor plate?
Is anyone making one that works with the front cover? There was a discussion on FABO about this, I don't recall the outcome. Maybe do a search over there.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Barry70GTX]
#1370053
11/04/14 02:03 PM
11/04/14 02:03 PM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
the Hemi and LS chevy motor mount bolt pattern on the block are the same, just not in the same location
[Re: GoodysGotaCuda]
#1370054
11/04/14 03:05 PM
11/04/14 03:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
72Swinger, looks great! Thanks for the pics! Is your mount an upper link mount off a solid axle, like a Jeep or Superduty front axle of some sort?
Close, Ram 2500 lower control arm.
Mopar to the bone!!!
[Re: Uhcoog1]
#1370055
11/04/14 03:11 PM
11/04/14 03:11 PM
Posts: 3,872 Smyrna, South Carolina
STEFF
It's easy enough to make one.
[Re: Uhcoog1]
#1370056
11/04/14 07:14 PM
11/04/14 07:14 PM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
OK....Of I read you wrong then I apologise...I treat these posts as a general cautionary dialogue....not blanket assumptions.....
.........but for clarification...
There is no 'maybe' about our K frames....they were imported directly from the US along with the small block V8s from 1962 to 1980.
Thats the reason our steering box is on the frame...They didnt bother re- stamping the cross members....all the room is on your driver side.
Im not sure the motor positioning why these TTI adapters are not a a problem with a B Body.....again that seems to be a factor.
All I can say is we had to take 1/2" out of the height of the US Drivers side adapter to achieve a decent pinion angle and " straighten" the motor....the height of the left side adapter crushed the top rear of the motor against the firewall and angled the motor across the engine bay.
Re- the headers...Most seem to have clearance issues .......So TTI will have to wear that one on the chin.
Seems RTV was the issue with the milodon pan....so your pics will save some heartache!
[Re: Uhcoog1]
#1370057
11/10/14 02:58 PM
11/10/14 02:58 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
If you need gen3 motorplates, Ive got em in stock. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: mr2performance]
#1370058
11/11/14 12:38 AM
11/11/14 12:38 AM
72Swinger
Nebraska
After 2 years of abuse by 1000-1100 RWHP worth of boost and spray, the stock main caps may show some weakness.....
[Re: 72Swinger]
#1370059
11/11/14 12:54 AM
11/11/14 12:54 AM
Posts: 310 Castle Rock, CO
wegner426
Castle Rock, CO
Avoid Total Seal rings on a 4.065 bore.
Can I ask for more info here? I believe I have Total Seal rings in mine, pretty close to the same bore as well. Don't have any issues to my knowledge in a forced induction motor, about 660 at the tire (so a mild build by many peoples standards). I was going more for longevity than HP.
[Re: wegner426]
#1370060
11/11/14 01:07 AM
11/11/14 01:07 AM
72Swinger
Nebraska
I need to re-quote myself a bit, avoid Manley spec Total Seal rings on Manley pistons.
Re: /6 k mod
[Re: roadrunninMark]
#1370064
11/12/14 12:54 AM
11/12/14 12:54 AM
72Swinger
Nebraska
Sucks but, pans are either front or rear sump. A couple main cap bolts wont break the bank.
Re: /6 k mod
[Re: 72Swinger]
#1370065
11/12/14 01:30 AM
11/12/14 01:30 AM
Posts: 833 MN
hemidup
MN
I think the Hemi Durango's have a mid sump pan. ???
Jerry Williams.
Re: Intake gaskets
[Re: mcat4321]
#1370067
11/12/14 01:54 AM
11/12/14 01:54 AM
Moparmal
FelPro work well, as do Cometic. I'm told.....
part numbers please
Cometic C5197 Mopar Perf 5153758 Fel Pro MS96916
The Fel Pro looks a lot like the factory gasket with rubber o ring style lips - not sure Id trust it on a non- oem intake.
Re: Intake gaskets
[Re: Moparmal]
#1370068
11/22/14 05:39 AM
11/22/14 05:39 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
After reading this post why would anyone build a performance 5.7...?? just to have a HEMI??
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
Re: Intake gaskets
[Re: 72N96RR]
#1370069
11/23/14 10:30 AM
11/23/14 10:30 AM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
Because they are readily available and can be easily modified to handle big power.
Re: Intake gaskets
[Re: 1badx]
#1370070
11/23/14 06:10 PM
11/23/14 06:10 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
It sounds as it comes with a high price from broken or inferior parts...I hope its worth the trouble and expense...badazz car by the way!!!!
Re: Intake gaskets
[Re: 72N96RR]
#1370071
11/23/14 07:34 PM
11/23/14 07:34 PM
72Swinger
Nebraska
It sucks that the aftermarket hasn't offered an affordable "Gen III Hemi color by numbers" kit to the public. Im gonna get mine figured out and not look back.
