Re: Gen III Hemi, please post things to avoid,,,,,,,,,
[Re: gregsdart]
#1369892
01/17/13 01:58 PM
01/17/13 01:58 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
Do the Gen III Hemis use throw away stretch to yield bolts? Where?
Primary head bolts. The secondaries are reuseable.
I see a lot of the gaskets appear to be reusable. Please post your experiences.
I've seen people take apart the multi layer steel gaskets and reshim them to gain or lose compression. I've never tried it. How good/bad is the stock timing chain? Good low priced alternative? High hp high rpm alternative?
I like the OE dodge ones, but manley has an adjustable offering I believe.
At what point do tie bars for the rocker shafts start to really show a hp gain?
You wont see power from them, just stability and resistance to failure. The Hemi heads flow so well, the reaction to various cams must be different than say a stock small block. Anyone care to share what they know about duration,ICA and LSA?
That's a broad subject. I might be able to drum up some good conversation about that. Can the new Hemi heads run a higher compression ratio in comparison to an aluminum head small block?
Yes, aside from the fact that it is aluminum...the fact that it's a dual plug and an awesome chamber helps the most.
[Re: AlexP]
#1369893
01/20/13 10:39 AM
01/20/13 10:39 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
With the drag pack cam, (229int 236 ex duration, 110 lobe seperation) what kind of torque curve am i looking at with a 3.888 arm? Any idea where to install it? My guess is start at 104? This will be a street motor with the Edelbrock dual four combo and two 500 cfm carbs, SRT8 jeep manifolds for exhuast. Thanks very much to all those that have contributed, and keep it coming. One thing I heard was the motor should be pre oiled, can be done through a pipe plug by the oil filter mounting location . Anyone care to add to that ? (equipment, does the motor need to be turned over, etc)
[Re: gregsdart]
#1369894
01/20/13 10:51 AM
01/20/13 10:51 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
While my 5.7 was a stock .30 over rebuild , I had no problem dry starting mine. I filled the oil filter up and it didn't roll over about 1 full turn and fired right up.. It took just a couple of seconds to build oil pressure , just like a oil change.. For that small amount of time I don't see any reason not to dry start them.. ![](/ubbthreads/images/graemlins/Twocents.gif)
6.50 @105.26
[Re: gregsdart]
#1369895
01/20/13 02:52 PM
01/20/13 02:52 PM
Posts: 25,995 Rio Linda, CA
John_Kunkel
Rio Linda, CA
After seeing this pic I think I would avoid using the factory (powdered metal) rods.
[Re: John_Kunkel]
#1369896
01/20/13 03:52 PM
01/20/13 03:52 PM
gregsdart
I have a set of rods out of a Drag Pack motor. I also see a lot of guys on the internet having reasonable life out of their motors after being hot rodded some, so I have to ask about the rod failure, how much rpm, any boost involved, timing, fuel, rpm, etc to find out what is the danger zone? On the block, I beleive the 5.7 has a fair amount of meat in it, but needs to be sonic checked to go beyond the minimum anyway. This may not be true on the 6.1 or 6.4. I talked to Chuck Lofgren about it, but only remember what was needed with my build, the 5.7 block. It is too bad they limited this motor to four bolts per cylinder. That is a big obstacle to overcome (if it can be at all) beyond a certain boost level. One more thing, Anyone with solid evidence that some facts presented hear are wrong, please say so. A lot of what I have written here is second hand info, not hands on experience.
[Re: John_Kunkel]
#1369897
01/20/13 04:20 PM
01/20/13 04:20 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We will be assembling our Gen3 Hemi next month and have it on the dyno by the end of the month. Unlike previous engine builds for CC where we take pics BEFORE the build, I will have BEFORE pics available, but we will be tearing the engine apart AFTER the dyno session and taking pics then.
We are looking for problems as well since we have to stand behind every engine we build and we don't want anything coming back or failing!
Once we do that, I'll probably start a thread about things we find. I believe it won't detour any work away from our shop but more importantly bring us work by helping others out and sharing info that will encourage potential customers to have us do work for them because we instill confidence BY SHARING our findings. We don't have to give away all build info to help guys out so they have reliable engines IMO.
From what I can see, some light massaging of the passages will make a big difference, Manley oil pump and timing set, aftermarket crank is a nice upgrade (plus more TQ and HP)if you go with more stroke. Our builds will be based on 5.7 blocks and 09' and later 5.7 heads. The cam cores are really cool looking as they are very beefy and heavy!!
Just received our Ritter intake so now it's time to finish machining and assemble. We're also using Clevite H series bearings and Diamond pistons. Crank is a Scat 3.900 unit with a 6.200 rod so we can use shelf Diamond pistons meant for the 4.050 stroke and 6.125 rod. Brian
Brian Hafliger
[Re: Brian Hafliger]
#1369898
01/20/13 11:10 PM
01/20/13 11:10 PM
gregsdart
Brian, thanks for adding to the thread. This thread, and your build and subsequent thread should really move forward the info provided on this site! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: gregsdart]
#1369899
01/21/13 03:22 AM
01/21/13 03:22 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Thanks Greg for getting this rolling, I know there alot of guys who need to "come out of the closet" with what they have figured out about these little monsters.
Mopar to the bone!!!
[Re: 72Swinger]
#1369900
01/21/13 08:12 AM
01/21/13 08:12 AM
Posts: 2,470 Answering the call of the wild
ThermoQuad
Great thread and idea.
Some one in charge should compile the info from the individual posts into a Gen III Hemi FAQ document and update the tech bulletin from time to time.
[Re: ThermoQuad]
#1369901
01/21/13 08:35 AM
01/21/13 08:35 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Good topic. I'm building a 5.7 for my daily '73 Dart at the moment.
The motor I bought for this project turned out to have a badly worn no.8 journal. The rodbearing on no.6 was also spinning already.
What I noticed was that the pistons didn't move freely on the rods. Especially on no.8, which was pretty tight. I wonder if other engines has this problem aswell, and maybe some of the failure-rates can be also 'blamed' on the piston-pins getting stuck in the pistons due to lack of (general) oiling? The heads looked dirty and black-ish on top aswell. Probably lack of oil, or/and engine operatingtemps too high?
[Re: BigBlockMopar]
#1369902
01/21/13 10:51 AM
01/21/13 10:51 AM
gregsdart
Thanks guys. We can keep this near the top and keep getting more info with a little effort! Here is a link to a lot of info- basic stuff. http://www.allpar.com/mopar/new-mopar-hemi.html
[Re: BigBlockMopar]
#1369903
01/21/13 10:53 AM
01/21/13 10:53 AM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
I see a few references to the bottom ends being "weak". Just a suggestion, if you're gonna post something like that you better have solid proof to back it up and not just be posting BS hearsay rumors that probably spawned from a Chevy site. In the mean time, go for a street ride atop a 9.50-second 1200 HP Grand Cherokee SRT8 http://www.youtube.com/watch?v=EdPcNz_y6EQhttp://www.youtube.com/watch?v=bj15UbJxBBc
[Re: BigBlockMopar]
#1369904
01/21/13 10:59 AM
01/21/13 10:59 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
The last 5.7 I found for a build, had 4 main bearings spun and one cam bearing spun. Appeared to have been ran out of oil for some reason. Maybe oil pump failure or just lack of oil in pan. The cam bearing housing bore checked OK and the main bearing housings will be align bored/honed with new caps, as the original caps were very loose fitting.
If you like drag racing, support your local track.
[Re: SRT6776]
#1369905
01/21/13 11:12 AM
01/21/13 11:12 AM
gregsdart
[/url]
That is the purpose of this thread, to get to the bottom of a lot of info and finally compose a good reference for all to use. If you have something to add as to how far a particular version of our beloved Gen III Hemi can be pushed, please post. Most builds will start with some stock parts, so that is where we need the most input.
#1369906
01/21/13 12:03 PM
01/21/13 12:03 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Once we do that, I'll probably start a thread about things we find. I believe it won't detour any work away from our shop but more importantly bring us work by helping others out and sharing info that will encourage potential customers to have us do work for them because we instill confidence BY SHARING our findings. We don't have to give away all build info to help guys out so they have reliable engines IMO. That right there is the first most important statement that I have seen in a while. BIG ![](/ubbthreads/images/graemlins/thumbs.gif) to you Brian. I dont need your HP secrets, Just put to bed this oiling issue. ![](/ubbthreads/images/graemlins/Twocents.gif) Looking forward to your posts. Matt
[Re: MattW]
#1369907
01/21/13 12:39 PM
01/21/13 12:39 PM
BigBlockMopar
The Netherlands
Here's a little tidbit I found that describes oilpump differences between 5.7 and 6.1 Hemi's. Quote:
• Chrysler 6.1L Hemi (2005 and newer): The M362 oil pump is a new replacement pump for late model Chrysler 6.1L Hemis. It replaces Chrysler 5037687AB, and features a 15 PSI higher pressure relief spring to accommodate oil jets to cool the pistons. For the 5.7L Hemi, Melling’s M342 oil pump replaces the stock Chrysler’s 53021622AF pump. Melling’s 10342 Select Performance high pressure pump can be used with either the 5.7L or the 6.1L Hemi engines.
[Re: gregsdart]
#1369908
01/21/13 05:33 PM
01/21/13 05:33 PM
Posts: 833 MN
hemidup
MN
I've sonic checked dozen's of G3 blocks. The thickest ones are from 2002 Ram 2500 5.7's but those are rare to get. Most of the 03 and newer 5.7's can easily withstand a .060" over bore whereas most 6.1 blocks only .020". My for the day.
Jerry Williams.
[Re: hemidup]
#1369909
01/21/13 05:57 PM
01/21/13 05:57 PM
AlexP
Houston, Tx
I just traded a 6.1 .030 block that needed another .010 to clean up for a stock bore 6.l plus cash. For my blower build I plan on going .005 if I can get away with it and .010 at most.
[Re: AlexP]
#1369910
01/22/13 07:47 PM
01/22/13 07:47 PM
Posts: 72 San Angelo, Texas
Cevidicus
San Angelo, Texas
What about the VVT blocks? How beefy are they? How much power can they take in stock form? Will that Eagle oil pump interchange with the Appache oil pump? Is there a difference between the timing sets? How much cam can the stock eagle springs take?
[Re: Cevidicus]
#1369911
01/23/13 12:44 AM
01/23/13 12:44 AM
Posts: 833 MN
hemidup
MN
From what I've seen, the 6.4 block looks to be the beefiest of them all. The bottom of the cylinder walls are casted the same as the World aluiminum block. Basically what you get is a partial filled factory block, however I'm not to happy with the looks of the narrrow 6.4 timing chain. I think forum member STEFF has an answer to this as well as member CHAPPER who has the answer with his custom spring locator's when using the Manley 5.7/6.1 NexTek Series replacement springs on 6.1 G3 heads.
