Re: New Eddy dual quad vs old DQ Modman - first notes
[Re: cudaman1969]
#1370155
03/13/15 09:20 AM
03/13/15 09:20 AM
Posts: 361 Canada
onig
Canada
In regards to the left and right head. EGR is one issue, just plug as you mentioned. I have a set of Apache heads and are L & R. It is the oil drain-back holes that you need to look for, I am guessing that the 5.7 are the same as well. But check to make sure. I have circled where the oil hole is, as you can see because of this they are not interchangeable. I believe the hole can be drilled as there is material there to make a hole. Also on these heads the exhaust manifold holes are drilled differently but can easily be drilled and taped as there is plenty of material there as well. Just check your 5.7 heads to make sure all is OK with the oil drain-back. Let us know what you find. I have 5.7 but it is still sitting on a shelf.
69 Dart
[Re: cudaman1969]
#1370156
03/13/15 09:21 AM
03/13/15 09:21 AM
Posts: 361 Canada
onig
Canada
By the way, what year is that engine and what did it come out of?
69 Dart
[Re: onig]
#1370157
03/13/15 11:24 AM
03/13/15 11:24 AM
Posts: 8,925 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
06 and 07. You are right, the drain back hole would have to be drilled. The problem I see is closing the other hole since the head gasket is dead center. Plugged and milled flat. Plug one and drill another or make headers, not sure what would be easier for most people. At least with headers they can be placed in the best spot. Thank you Chrysler. The water hole would need grinding too.
[Re: krw71ragtop]
#1370159
03/17/15 03:46 PM
03/17/15 03:46 PM
Posts: 154 Plano, TX
StricNine
Plano, TX
I have some questions on the 5.7 engines. Will the heads, intake, cam, oil pump, and timing set from a 2003 truck engine interchange on a 2014 short block truck engine ? I have both engines complete but the 2003 engines oil pump failed and wiped out the rod and main bearings.
I was hoping I could take the heads and freshen them up on the 2003 engine and bolt them and the intake on the 2014 motor. I'm guessing since the 2014 engine has the vvt that the cam shaft, lifters, pushrods, timing set would be different ? Would the block and pistons be different ? Not sure how much they changed the block, what will and won't plug in, or if all the accessories on the front of the engine from the 03 will bolt on the 14 ? I'm just trying to save some time and money by using what I have. Otherwise I'll have to rebuild the 2003 motor while the 2014 motor takes up floor space in my garage!
Lifters: Keep the '14 lifters, they support higher lift with MDS, and can be used to replace lifters in 08 and older 5.7's. Cam: No Timing Set: No Pushrods: No, Eagle head valves are taller. Intake/Head pair work together. Fitment on a 09+ block? Don't know, if they do the older heads have larger chambers and will drop compression. I'd recommend Eagle intake/heads over the older 5.7's. Also the Eagle truck intake, I believe, has short/long runners controlled by the PCM.
StricNine
79 Li'l Red Express, 15.04 @ 89.57 09 Challenger R/T, 11.95 @ 115.92
Re: Gen III Hemi, please post things to avoid and know..
[Re: gregsdart]
#1812094
04/26/15 12:40 AM
04/26/15 12:40 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Don't forget the oil galley plug in the front of the engine, didn't know it existed until today....
Mopar to the bone!!!
[Re: gregsdart]
#1816456
05/01/15 02:59 PM
05/01/15 02:59 PM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
Can the stock cams be reground?Could save some cash that way I would think. Probably have to harden the lobes, but they do that to the new ones anyway right?
[Re: cudaman1969]
#1816976
05/02/15 10:35 AM
05/02/15 10:35 AM
Posts: 10,168 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Can the stock cams be reground?Could save some cash that way I would think. Probably have to harden the lobes, but they do that to the new ones anyway right? Hughes had some regrinds listed on their web site. There are limits, due to the stock lobe dimensions and LSA . Depending on what you want to do, a custom cam may really be needed. In a deal like my build, (stroker, big heads, not as worried about torque below 2,500, totally programmable computer) it only makes sense to have one cut, or in my case grab a drag pack cam if you can find one cheap!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: ntstlgl1970]
#1818204
05/04/15 12:24 AM
05/04/15 12:24 AM
72Swinger
Nebraska
If you add external oiling to the block, the fittings may interfere with the back of the alternator That is why I used a remote filter adapter instead of the block off plate.
[Re: gregsdart]
#1818964
05/04/15 10:43 PM
05/04/15 10:43 PM
72Swinger
Nebraska
Those idlers are for a VVT engine which has all the accessories spaced out further, about 1/2".
[Re: hudsonhornet7x]
#1819289
05/05/15 11:49 AM
05/05/15 11:49 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Does anyone know the difference between an apache head and a hellcat?
I am aware they are a different alloy, but what about valves, springs, flow, etc. Thanks! The hellcat heads don't interchange, the intake manifold bolt pattern is different to mount the supercharger. look at this picture from a hellcat supercharger on ebay http://i.ebayimg.com/00/s/OTA0WDE2MDA=/z/lDMAAOSwBahVLVwH/$_57.JPG http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/e9MAAOSwBLlVKmRn/$_57.JPG I save the pictures before they disappear. It does look like you could have the intake bolt pattern drilled to match the eagle/apache/6.1L heads since the bosses are cast into the head but undrilled.
