Re: How many teeth on hemi [Re: JohnRR] #1369769
01/17/13 08:27 PM
01/17/13 08:27 PM
California
mickm Offline
mickm  Offline
California
hope this isn't hijacking the post, but i had the 11" setup and went to the 10.5" setup, which i believe in this case is really the 10.95".
i went from the 142 to the 130 tooth flywheel. i have a mini-starter on there now.
am i going to need a different starter?
Headers or manifolds ?
you shouldn't have an issues , mini and a 130 should work fine . it's manifolds where things get tight.
headers.
good to know, one less thing to buy!
thanks!
Re: How many teeth on hemi [Re: mickm] #1369770
01/17/13 10:00 PM
01/17/13 10:00 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run an old Ansen steel bell with a 143 tooth wheel and a Mopar factory V-6 starter with Doug's D-452 2" tube headers with no problems at all
If you just need a flywheel I can send you an old Hays steel wheel that can't be machined anymore
Just shoot me a PM and we can work out the details
Gus
64 Plymouth Savoy
Dana 60
Re: How many teeth on hemi [Re: Onewickedhemi] #1369771
01/18/13 01:47 AM
01/18/13 01:47 AM
Area 51
Onewickedhemi Offline OP
Area 51
Thanks Gus, PM sent.
Fred
Re: How many teeth on hemi [Re: Onewickedhemi] #1369772
01/18/13 04:18 AM
01/18/13 04:18 AM
California
mickm Offline
mickm  Offline
California
Fred
fred, you sent the PM to me, not gus. your account doesn't seem to be accepting PM's, may want to look into that!
Re: How many teeth on hemi [Re: fourgearsavoy] #1369773
01/18/13 11:15 AM
01/18/13 11:15 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Gus
Gus , when did you buy a HEMI ? He needs an 8 bolt (I assume his crank is 8 bolt) 130 tooth wheel
