Re: 71 charger driveshaft specs? 440/727/8.75
[Re: carcrazyguy]
#1367367
01/10/13 12:48 PM
01/10/13 12:48 PM
RapidRobert
since you're having one built I'd shove the yoke you plan to use into the trans all the way & measure the C to C distance then subtract 3/4-7/8" from that dimention (suspension loaded & assuming flat common aftermarket trans extension housing rear seal)
[Re: Nuke463]
#1367372
01/11/13 07:31 PM
01/11/13 07:31 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Dunno, but it seems is carb related... WHY? I have no idea.
EDIT:
maybe sedans ?
