Re: RB Build - How difficult will these goals be?
[Re: BSB67]
#1367341
01/10/13 11:51 PM
01/10/13 11:51 PM
Posts: 1,664 NE Iowa
Road_RunnerSteve
NE Iowa
Is that your all in budget, or just the motor? And, what parts do you already have for the 440?
I have 0 parts right now. I may be picking up a core from 500ciDuster, though. I'm headed over to his place tomorrow to chat.
[Re: Road_RunnerSteve]
#1367342
01/11/13 03:38 AM
01/11/13 03:38 AM
DaytonaTurbo
Manitoba, Canada
It's likely to be somewhere in between, probably closer to 2K than 5.
2k won't get you much. 2k gets you a cleaned up 70's smogger 440 with fresh paint and a couple bolt ons. Hell, 5k gets spent quick enough!
If all you want to do is break into the 12's, a basic quick and dirty 440 combo can get you there. Normally I would advise going straight for a set of 440source or edelbrock rpm heads, but it sounds like that may be outside the budget. If you hunt around, you can find used runnable iron heads for a couple hundred bucks. Can't be picky about which casting they are though. Get a set of speed pro hyper 143 pistons or trw2355's and with a set of normal open chambered heads you should end up around 9.5 compression. Then toss in the big summit cam, el cheapo summit headers, used edelbrock ch4b intake and a holley 750 vacuum carb and you should basically be there. At least with those pistons later on down the road you can get a set of closed chambered aluminum heads and set them up for quench and upgrade the rest of the top end when you want some more power.
[Re: DaytonaTurbo]
#1367344
01/11/13 02:54 PM
01/11/13 02:54 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
This is pretty much what I did - TRW 2355s, except I used an Engle 238 @ .050, .534 lift cam, a used Edelbrock Performer RPM intake, used Hooker 1 and 7/8" headers, and a 850 DP - all from eBay. 7.86 @ 86.7 in the 1/8 mile so far, that would be around 12.30-12.40 in the quarter. So I think your goal is doable but closer to 4K than 2K like was said above.
When I upgrade when time and funds allow, it will be to some aluminum heads and a solid lifter cam with a little more duration and lift.
Also, what about setting it up for E85 right from the get go? I guess you'd need a lot more compression to take advantage. I'd imagine E85 is readily available where you are in Iowa.
[Re: 67Satty]
#1367345
01/11/13 03:44 PM
01/11/13 03:44 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Even at a relatively low compression, you will see a fairly significant torque increase with E85. I ran it for awhile with 10.5 comp. The torque increase was as I was told it would be.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: scrag]
#1367346
01/11/13 03:57 PM
01/11/13 03:57 PM
DaytonaTurbo
Manitoba, Canada
Not sure if you looked at the suspension and tire combo....might want to budget on that as well....I am building a stroker and know this will be an issue - for me as well..
tires, suspension and gears will need to be addressed as well.
[Re: 67Satty]
#1367348
01/11/13 06:08 PM
01/11/13 06:08 PM
Road_RunnerSteve
NE Iowa
Actually I'd have to drive 20 miles to get E-85 believe it or not...
[Re: rbstroker]
#1367349
01/12/13 02:26 AM
01/12/13 02:26 AM
Posts: 6,572 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My 8.97:1 493 stroker made 500hp/600ft/lbs on 87 regular and does it all by 5000 RPM, just to give you an idea what displacement can do for you. It's a zero deck with RPM heads and .039 quench.
Kevin
Twostick....please elaborate on your combination.
Long story .
76 440 truck block
4.15 440Source kit, Mopar journals. Ross pistons with IIRC 34 CC dish zero decked and squared 8.97:1 CR
.509 cam 108 lsa installed straight up 1.7 rockers
RPM heads cleaned up with a good valve job.
M1 single plane with Holley Commander 950 Pro TBI
It made over 500 ft/lbs from 2000 thru 5500 and peaked 600 at 4000.
500 hp @ 5000
If I had to do it over, I wouldn't use that cam again. The EFI doesn't care for the overlap at low RPM.
Kevin
#1367350
01/12/13 03:51 AM
01/12/13 03:51 AM
Posts: 43,372 Bend,OR USA
Cab_Burge
500 HP out of a 360 stroker with decent heads is very easy to do, 600 HP from a 512 C.I. bb is easy to do also Money is always a deciding factor I would look around your area and see what I could buy a good core trans and engine for and go from there. A late model 360 with trans would be a good start as long as the block will bore to 4.060 and then look at a 4 inch sroker crank kit, a good set of aluminum heads, rocker assembly, intake and carb. and torque converter, headers, ignition and so on Same deal on a late model 440 or 400, looking for a rebuildable core trans and motor IMO the better choice is the 400 My first 512 stroker 400 made 612 HP at 5600 RPM and 644 ft. lbs torque at 4500 RPM on CA pump gas, it did have a decent set of mildy ported iron 906 heads and s good solid roller cam with a six pak, same combination with a single four barrel intake and carb. might make 10 to 20 HP less, same torque lots of choices out there Do your home work before deciding
#1367351
01/12/13 10:48 AM
01/12/13 10:48 AM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Wow, some pretty interesting responses.
I don't think you answered my first question....is that an all-in number, or just the motor.
So, I'll assume its your all-in number. And for talking purposes let’s say it is $3,500. If it is, I think you have a challenge in front of you, but if you find the right used stuff for the right price you could probably do it IMO. You will need to be very very diligent.
If you go 440, I don't see how you can even go into the short block, put it all together, get it in the car and running for that kind of money.
Get a running pan to carb 4bbl 440 w/ tranny, Rebuild the tranny probably need a radiator spend $1200 on a set of GOOD heads (reworked 915, or Stealths) Rebuild the carb Used Holley SD New cam, lifters and springs new fuel pump Spark plugs cap and plug wires put an exhaust system on Drive shaft?
This, with all the other stuff, bolts, gaskets, fluids, cleaners, paint, belts, hoses will probably get you close. The only way you could get a fresh short block out of this is if you find someone needing to get off of one pretty bad, but then you won’t have all of the accessories.
This is what I'm assuming you don't need to purchase separately,
gear torque convertor any suspension stuff water pump steering pump fan valve covers Air Cleaner oil pump distributor and ignition system rockers/shafts/push rods throttle/kick down stuff alternator
[Re: JohnRR]
#1367354
01/13/13 11:35 AM
01/13/13 11:35 AM
Posts: 9,897 MI, usa
dvw
MI, usa
Easily attainable with a 440 , quench and compression at 9.5 with an iron head.
NO,NO ,NO. 9.5-1 w/ quench barely runs on 93. I built one for my body guy. Granted it has a stock cam and 3.23 gear, but I wouldn't chance it. And yes it has modified chambers that have been opened equally and fitted at .040" quench. It was a lot of work for something that didn't work. I've done quench in the past so I'm not new to it. Small blocks respond great. The 906/452 head has a lousy chamber plug location and chamber shape. Stick with a modern aluminum head w/quench. Doug
#1367355
01/13/13 01:31 PM
01/13/13 01:31 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
How difficult will it be to reach these goals with the '71 B-Body? A: It's not difficult at all.
What would you recommend for the engine build? A: An RB wedge, even low compression with the right bolt ons and matched power train is plenty and will fit your budget.
I'd prefer to keep the budget as low as possible while still meeting these goals - what should I expect to spend? A: Starting with a running core w/good oil pressure I'd expect to spend $2000 on bolt ons and another $2K on the transmission, convertor, and rear axle.
You don't need quench, new heads, or special cams. You need a solid running engine - if you don't have that add another $4K to the engine budget for a budget performance rebuild using factory heads. A simple 8.5:1 mid-70s 440 with a good dual plane intake, a 770 Street Avenger carb, a cheap set of headers, a cam in the 230° @ .050 area, and a good ignition will more than do. Get a convertor around 2200 and rear gears in the 3.55 range (or 3.91s depending on tire height). Tune it, and you should be able to eclipse your expected ETs and drive it anywhere.
[Re: moper]
#1367356
01/13/13 02:14 PM
01/13/13 02:14 PM
Road_RunnerSteve
NE Iowa
Thanks!
[Re: moper]
#1367357
01/13/13 04:09 PM
01/13/13 04:09 PM
BSB67
Prospect, PA
Do I understand this correctly, If he already has a good long block, with all the accessories, add $2000 for engine add-ons and $2000 for suspension stuff. Add an additional $4000 if you actually want an engine. I agree with this meeting the performance goal, but seems to miss the $3,500 mark as he has no engine or transmission.
