Re: Downshift kickdown 727.
[Re: John_Kunkel]
#1366290
01/09/13 05:57 PM
01/09/13 05:57 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I have thought about manually dropping it from 3-2 but never had the guts to do it at a WOT stab in the fear that it would rev too high too quick. This is why I was looking to be able to modify the auto kick-down feature to keep it safe. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1366291
01/09/13 06:25 PM
01/09/13 06:25 PM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
May be if we use the 426 governor and the 3.23 axle ratio you can have 3 to 2 downshift from 70 to 84 mph as per the shop manual. Will be our target...
[Re: STROKIE]
#1366293
01/09/13 07:27 PM
01/09/13 07:27 PM
YO7_A66
Indiana
My problem is that I want to keep my 3:91's, so I will have to do something with the governor assembly. I have already emailed A&A to see what my governor options might be for this. Note: My valve body has been upgraded with the 71 & later PTK. Thanks
[Re: YO7_A66]
#1366294
01/10/13 03:21 PM
01/10/13 03:21 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the '71-later PTK module is installed on a pre-'71 VB the limit valve won't function.
[Re: John_Kunkel]
#1366295
01/10/13 03:39 PM
01/10/13 03:39 PM
YO7_A66
Indiana
I should have wrote that my valve body is a 71 or later model with the PTK.
[Re: STROKIE]
#1366296
01/10/13 07:57 PM
01/10/13 07:57 PM
STROKIE
Montreal Quebec
I would like to know how Chrysler can downshift the Torqueflite 727 3-2 downshift with 3.23 axle ratio from 70-84mph (I prefer 84 mph.) many Moparts fan will be happy. John kunkel may know...
[Re: STROKIE]
#1366297
01/10/13 08:14 PM
01/10/13 08:14 PM
John_Kunkel
Rio Linda, CA
Once again, it's all about the governor and the axle ratio.
A trans with a Hemi governor and and 3.91 gears might not 3-2 kickdown above 70 mph while the exact same trans with 3.23's might still kickdown at 84 mph. The governor only knows the rpm of the output shaft, not the road speed of the car.
84 mph in 2nd gear with 3.23 gears is around 5000 engine rpm, within the limits of the Hemi governor.
[Re: John_Kunkel]
#1366298
01/11/13 10:19 AM
01/11/13 10:19 AM
STROKIE
Montreal Quebec
A&A transmissions sell many Governor Kits from 5000 to 6000+ rpm... They have 2 different Hemi governor kit 5400 & 5600 rpm. As per shop manual Wide Open Throttle 2-3 Upshift with 3.23 Axle Ratio can be at 93 Mph must equal to around 5800 rpm. Logically I must order the 5800 Rpm Max Wedge governor kit to upshit at 93 mph and kickdown at 3-2 kickdown at 84 mph.
[Re: SomeCarGuy]
#1366300
01/11/13 07:50 PM
01/11/13 07:50 PM
STROKIE
Montreal Quebec
Might tire size account for the ranges that are given on MPH with the various gear sets?
A&A transmissions sell many Governor Kits from 5000 to 6000+ rpm... They have 2 different Hemi governor kit 5400 & 5600 rpm. As per shop manual Wide Open Throttle 2-3 Upshift with 3.23 Axle WITH 26 INCHES TIRES. Ratio can be at 93 Mph must equal to around 5800 rpm. Logically I must order the 5800 Rpm Max Wedge governor kit to upshit at 93 mph and kickdown at 3-2 kickdown at 84 mph.
[Re: STROKIE]
#1366301
01/11/13 08:41 PM
01/11/13 08:41 PM
John_Kunkel
Rio Linda, CA
Hemi cars traditionally had 15" tires which were closer to 27" in diameter.
[Re: John_Kunkel]
#1366302
01/12/13 10:29 AM
01/12/13 10:29 AM
STROKIE
Montreal Quebec
My car is a Dodge Charger 1967 as per the shop manual Hemi cars are fitted with 7.75-14 can be close to 27" in diameter.
