Downshift kickdown 727.
#1366270
01/08/13 11:19 AM
01/08/13 11:19 AM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
I would like to know if it's possible to raised the kickdown downshift speed... Actually my 3 to 2 downshift occur at 65mph after this speed I don't have no more kickdown. Will be fun to have higher speed kd Thanks
Re: Downshift kickdown 727.
[Re: STROKIE]
#1366272
01/08/13 11:33 AM
01/08/13 11:33 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I asked this question a couple of years ago and the general response at that time was no. The auto 3-2 downshift occurs depending on what parts you have in the tranny, plus rear gear and tire diameter.
Mine does not auto downshift any higher than about 60-62mph, currently. I would like to raise mine too if possible, maybe 70-75mph or so and without changing the current WOT shift points.
BUMP!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: dOoC]
#1366275
01/08/13 11:52 AM
01/08/13 11:52 AM
YO7_A66
Indiana
In my case, I have my linkage maxed out to give me the WOT shift points that I want. I have tested with different 1-2 and 2-3 shift springs and line pressures to give me a 5700rpm shift at both the 1-2 and the 2-3 at WOT. This is by using a 5600rpm governor kit and a TF-2 kit. If I put in my 5800rpm governor kit, my shift points go up to 5900/6000rpms which is too high for my setup. So I am right where I want to be for the shift point setup and I want my cake too. If I could find an easy way to raise the 60-62mph auto 3-2 downshift without messing up the above, that would be great. But I don't know enough about it, so I gave up until I read this thread. Thanks Doc BUMP
[Re: STROKIE]
#1366279
01/08/13 02:57 PM
01/08/13 02:57 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The only way to raise the forced kickdown road speed is to install a high-speed governor or change to a lower numeric axle ratio.
[Re: YO7_A66]
#1366280
01/08/13 05:01 PM
01/08/13 05:01 PM
STROKIE
Montreal Quebec
As per John Kunkel you need to raise the governor rpm... You already have a high speed governor, 5700rpm and this give give you only 60-62mph 3-2 downshift not very high... I don't know the stock governor rpm but 3-2 downshift must be lower Not very exciting.
[Re: John_Kunkel]
#1366282
01/08/13 08:16 PM
01/08/13 08:16 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
The transmission has no idea what the road speed is, it only knows output shaft speed. So the forced downshift lockout road speed will vary greatly with the axle ratio.
The chart below shows the relationship of axle ratio and governors....note the difference in 3-2 forced downshift speed with the same gears but different governors.
As will different gearing change shift points using the same governor.
[Re: John_Kunkel]
#1366283
01/08/13 08:28 PM
01/08/13 08:28 PM
STROKIE
Montreal Quebec
I wish to have the 3-2 kickdown limit set up of the high performance 426 3.23:1 in my Dodge Charger 67 (70-84) will be better than my 65mph downshift... May be the 426 have different rear end ratio
[Re: STROKIE]
#1366284
01/08/13 09:19 PM
01/08/13 09:19 PM
STROKIE
Montreal Quebec
I wish to have the 3-2 kickdown limit set up of the high performance 426 3.23:1 in my Dodge Charger 67 (70-84) will be better than my 65mph downshift... John Kunkel may you can help us to know the way to have the 3-2 kickdown limit set up of the high performance 426 3.23:1 in my Dodge Charger 67 to (70-84mph).
[Re: YO7_A66]
#1366286
01/09/13 03:01 PM
01/09/13 03:01 PM
John_Kunkel
Rio Linda, CA
Here's a revolutionary idea...grab the shifter and pull it into 2 instead of depending on the kickdown.
[Re: John_Kunkel]
#1366287
01/09/13 05:00 PM
01/09/13 05:00 PM
STROKIE
Montreal Quebec
How come I never tried that before I didn't know I can pull the shifter into 2 at 70 mph. Thanks John, simple thing in live are often the best...
[Re: STROKIE]
#1366288
01/09/13 05:15 PM
01/09/13 05:15 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Just don't grab 1st. LOL
[Re: mopowers]
#1366289
01/09/13 05:25 PM
01/09/13 05:25 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
John might know what trannys have a "limit valve". I know some do but I cant remember if all or only some do. Its a valve that once it gets so much gov pressure it will move and keep the tranny from down shifting above a certain road speed controlled by output shaft speed of course. Heck it may only be in FWD trannys as at the moment I cant remember I just remember it is some Mopar trannys and it will move to block off throttle pressure to the throttle pressure side of the 2-3 shift valve. But I agree to just pull the shifter down to second when you want to downshift. I have too do it that way with my manual shift valve body. But over 55 mph I dont need to downshift with the torque of my 493. Ron
