Re: Stock Holley Set-up???
[Re: mopowers]
#1365579
01/07/13 12:54 AM
01/07/13 12:54 AM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
The choke's been milled off, but the primary metering block and base plate booth have a 4779-2 on it, so I'm assuming that's the main body was/is... It's got four corner idles, so I'm not sure what the secondary metering block is. I just want to rebuild it and get it running better than the current Edelbrock that's on it now.
specs for a -2 are primary jet 70 secondary jet 80 power valve 6.5 primary nozzle .028 secondary nozzle .031
[Re: mopowers]
#1365581
01/07/13 05:16 AM
01/07/13 05:16 AM
Posts: 43,744 Bend,OR USA
Cab_Burge
Post apicture of the throttle linkage, you may have a 4779 original with no dash number, on the 4781(850DP)the original had different throttle linkage than the later dash carbs did, dfferent jetting also. BTW, Holley has made some later dash # like the -6 or -7 and later that had four corner idling on them stock The later 4781-7 work excellent out of the box You have a job ahead of you I have a Holley 850 that has the choke tower removed so I don't know which version it is,it had problems with the guy that had it before me, I took it in trade hoping to be able to make it work good but I haven't succeeded yet Maybe this summer after the Duster is gone
[Re: mopowers]
#1365583
01/24/13 02:31 AM
01/24/13 02:31 AM
Posts: 3,017 Sac, CA
mopowers
Sac, CA
So, I started rebuilding this carb. It is in fact a 4779-2 carb that has been converted to a 4-corner idle. Is that why this caulking type material is in these grooves? Should I take it out and replace it with something else. The grooves seems to lead to holes under the butterflies that I'm assuming are for the idle circuit. How should I deal with this? I have all the parts to convert this carb back to stock, but I also want to keep the 4-corner idle. The red arrows point to the grooves I'm talking about.
[Re: Mr.Yuck]
#1365585
01/24/13 11:40 AM
01/24/13 11:40 AM
mopowers
Sac, CA
Not sure about stock but on my old mild 340 swinger I ran 72-78, 6.5Pv and 25 squirters. Ran great not rich at all. 13.80's and 17mpg.
What Carb was it? Did it have a 4-corner idle?
