Page 3 of 3 1 2 3
Re: new best for the "land yacht" [Re: Crizila] #1365514
01/09/13 08:26 PM
01/09/13 08:26 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
The bigger pulley will be your detune.
Re: new best for the "land yacht" [Re: Duner] #1365515
01/09/13 08:39 PM
01/09/13 08:39 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Already on - along with NGK # R5671A-8's gaped @ .030". Think I will drop the timing back to 28 ( I was running 30 ) also. Hoping these changes will net me a clean run. Appreciate everyones input on this thread.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365516
01/09/13 08:58 PM
01/09/13 08:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Will help for vids!
So when you getting back out?
Re: new best for the "land yacht" [Re: FastmOp] #1365517
01/09/13 10:31 PM
01/09/13 10:31 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Will help for vids!
Not for a couple of weeks.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365518
01/10/13 05:06 AM
01/10/13 05:06 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Make sure your air bleeds are clean too.
Re: new best for the "land yacht" [Re: Crizila] #1365519
01/20/13 10:53 AM
01/20/13 10:53 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Will help for vids!
Well, got out to the track yesterday and finally made one clean pass and ran a 128.70 MPH. Unfortunately, track prep was poor and couldn't get out of the 1.50 range for 60 foot times, so only ran a 10.60 et. Next run lost the alternator belt, which took out the blower belt, which took out a trans cooler line, which promptly ended my day and shut down the track for a 45 minute clean up session. I did not get off the track as soon as I could have and I don't feel too good about that. Belt came off just before the lights ( ran a 126 on that pass ) and had my hands full getting it stopped with trans soaked tires.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365520
01/20/13 11:37 AM
01/20/13 11:37 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
If is wasn't for bad luck you wouldn't have any luck at all. See you at Firebird next week.
Raul
Re: new best for the "land yacht" [Re: Aspen7695] #1365521
01/20/13 12:35 PM
01/20/13 12:35 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Raul
It's on my schedule Raul, but doubt I will be able to make it. Haven't assessed all the damage yet. Still playing "clean up in isle 5".
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365522
01/20/13 07:42 PM
01/20/13 07:42 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Sounds like it's making some steam at the big end John.
Re: new best for the "land yacht" [Re: Crizila] #1365523
01/20/13 07:52 PM
01/20/13 07:52 PM
Raul
Time to take a break and look everything over very carefully More Power, more and quicker problems harder to fix, you've been lucky so far get the fine tooth comb out
Re: new best for the "land yacht" [Re: Cab_Burge] #1365524
01/20/13 10:35 PM
01/20/13 10:35 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Raul
Your on the money there Cab. Gonna go over my whole program in the next few weeks. Think I'll start by changing gears ( 4.56 to 4.10 ) to try and slow things down a bit. As it is, if the car doesn't hook real good, I end up going through the lights at around 7500 - which is part of my belt issues. The plug change I made solved the melting ground strap issues anyway.
Fastest 300
Page 3 of 3 1 2 3
