Re: new best for the "land yacht"
[Re: Crizila]
#1365494
01/08/13 02:19 AM
01/08/13 02:19 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
I'm suprised you didn't hurt it worst than you did with that hot of a spark plug your lucky iit only burnt the ground straps off I would go to a non protruded gap and a #9 or#10 as already suggested. The last blower motor I work on dyno testing was a 484 C.I. 426 Street Hemi, it liked 33 degrees with 7 lbs of boost using a 10:71 Littlefield roots, no intercooler, running 12 % under on CA pump gas, that combination made 927 HP at 7300 RPM after doing a lot of small changes on it to sneak up on what it wanted. We got greedy (the owner wanted more) and switched the pulleys around to make it have 13% overdrive, switch it to race gas, back the timing down to 25 degrees total and made another pull, it started into detonation slightly at 6500 RPM and still made 1027 HP at 6500 RPM (we pulled it to 7500 RPM on all the pulls except the last one) I moved the timing up to 28 degrees total and ended up aborting the run wjhen it started to go into detonation again Luckily it didn't hurt it I switch the pulleys back and told him when you get it to hook up with the pump gas combination call me and we would hop it up again,I never got that call My meassage is back that baby down some to be safe and then sneak up on it Maybe some day, if I ever when the lottery or my ship comes in, I'll try a compressor on some of my own junk, twin hair dryers with intercooling and EFI
[Re: Cab_Burge]
#1365495
01/08/13 09:30 AM
01/08/13 09:30 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
By switching from a msd digital 6 to a digital 7 (7531) got rid of top end miss fire and the ability to run the largest nozzle snow makes. Was able to add more timing and went from a best of 10.02 to 9.46.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Cab_Burge]
#1365498
01/08/13 11:52 AM
01/08/13 11:52 AM
Posts: 7,506 Az
Crizila
Az
As always, thanks for the info Cab. Definitely making a plug change and going back to the 4" blower pulley ( from the 3.7" ) until I can get a handle on it.
Fastest 300
[Re: Crizila]
#1365499
01/08/13 12:15 PM
01/08/13 12:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats a good looking boat you have... and runs well... hopefully its got 2 straps stuck in a couple of pistons and didnt hurt it
[Re: Cab_Burge]
#1365507
01/08/13 09:34 PM
01/08/13 09:34 PM
1967dartgt
Hilltown Pa
We run a -9 with 15-16psi and 8.8 static compression. 406 cu in small block.
