Equal length headers ?
#1364651
01/05/13 01:03 PM
01/05/13 01:03 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Had some header built last year for the car and requested 2 3/8 primary and 31 length. How critical is it that the header tubes are equal length. On both sides headers are approximately 31 length with the exception of one tube that is out almost two inches. A friend just a had a set built and his fabricator went to great lengths to make the tubes precisely the same length ?
76 Duster
work in progress
Re: Equal length headers ?
[Re: Edge]
#1364652
01/05/13 01:14 PM
01/05/13 01:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With a low LSA cam its more important... its gonna have a draw on the cyl at a more persist time to help the next charge... being a fabbed set they should be real close BUT sometimes it just cant happen... my race set are within .1 on all of the tubes
[Re: MR_P_BODY]
#1364653
01/05/13 01:46 PM
01/05/13 01:46 PM
Edge
Alberta Canada
Thanks for the info Mr P. LSA is 112 so this should help minimize the effect of the shorter tube. I was a little tiked to find out the one tube was that much shorter !
76 Duster
work in progress
[Re: Edge]
#1364654
01/05/13 01:53 PM
01/05/13 01:53 PM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
It won't make any appreciable difference at all. The most important thing with headers is matching the tube diameter and collector diameter. After that collector length. Primary tube length would be the least of my concerns.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Edge]
#1364655
01/05/13 02:22 PM
01/05/13 02:22 PM
MR_P_BODY
Basically the primary (diameter and length) are the rpm range and the collector is torque... being that you have a 112 LSA its not a major issue being it doesnt have a lot of scavenge going on(it still has it but not near as much as a 105 LSA)
[Re: Sport440]
#1364660
01/05/13 10:10 PM
01/05/13 10:10 PM
Edge
Alberta Canada
Thats good to hear. Will have to wait and see how restrictive the collector mufflers turn out to be but they really don't look to be very restrictive.
76 Duster
work in progress
