Slug on my K-frame #1364137
01/04/13 10:32 AM
01/04/13 10:32 AM
South Bend, Indiana
E
Ellies Dart Offline OP
E
South Bend, Indiana
I have 69 Dart Swinger 340ci 4-speed built at Hamtramck,Mi. On the front of the K-frame is a(factory) Quarter size slug welded to it with a #no on it(06?) Why do some car I see have it and some don't,and what does it mean? I have also seen them on E & B body also. Thank for any Help with this Bob
Re: Slug on my K-frame [Re: Ellies Dart] #1364138
01/04/13 10:46 AM
01/04/13 10:46 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Although I've never seen any documentation that explains it I have noticed that they are only on 340 cars. Up until recently I could not see anything unique about them, however after checking out a bunch of K-members comparing 340 to 318 cars (the 318 cars didn't have the slugs) I think I found out what they were for. The 340 units had a reinforcement piece which looks like a half of a large washer welded to the rear of the LCA pivot hole, likely due to the theory that 340 cars might be getting a bit more abuse. The slug was likely added and used as a quick identifier for workers when installing a K-member into 340 car since the reinforcement piece is not very obvious.
First pic here is a 340 and a 318 K-member (both are from 1971 Dusters)
Re: Slug on my K-frame [Re: ScottSmith_Harms] #1364139
01/04/13 10:48 AM
01/04/13 10:48 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the LCA hole on a 318 unit
Re: Slug on my K-frame [Re: ScottSmith_Harms] #1364140
01/04/13 10:50 AM
01/04/13 10:50 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the LCA hole with the reinforcement on a 340 unit
Re: Slug on my K-frame [Re: ScottSmith_Harms] #1364141
01/04/13 10:54 AM
01/04/13 10:54 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
340 unit with the slug on the front
Re: Slug on my K-frame [Re: ScottSmith_Harms] #1364142
01/04/13 11:42 AM
01/04/13 11:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Scott , you are comparing 71 duster K frames , the OP has a 69 Dart so do you really think it's a fair comparison ?
Re: Slug on my K-frame [Re: Ellies Dart] #1364143
01/04/13 11:57 AM
01/04/13 11:57 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Are you talking about the welded on "coin"? It is a part number that relates to the k-frame number on the build sheet. Seen coins welded on top of other coins to change the part number as well.....probably a vendor re-work in this instance - like adding a skid plate etc. to an existing non-skid K
Re: Slug on my K-frame [Re: JohnRR] #1364144
01/04/13 12:02 PM
01/04/13 12:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
All holds true from what I've seen so far regardless of the year. The 71's are all I had handy pics of.
FJ5, none of the A-body units I've seen had any numbers stamped into them, just a bare steel round slug welded a few inches away from the assembly date code on the drivers side front face of the K-member as shown in my pic above..
Re: Slug on my K-frame [Re: ScottSmith_Harms] #1364145
01/04/13 12:10 PM
01/04/13 12:10 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Could be right Scott - I have them on E's and B's....gonna have to look at the A stuff...
Re: Slug on my K-frame [Re: FJ5_Fish] #1364146
01/04/13 12:27 PM
01/04/13 12:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Be interesting to know if you have one on a 69 A body , I've never seen a coin on anything older than 70 ...
Re: Slug on my K-frame [Re: JohnRR] #1364147
01/04/13 12:45 PM
01/04/13 12:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'll see if I can find some John, it's possible that they were only added after finding earlier failures with 68/69 340 cars so it may be that 68's and 69's (or early 69's?) never had them.
Re: Slug on my K-frame [Re: ScottSmith_Harms] #1364148
01/07/13 07:03 AM
01/07/13 07:03 AM
South Bend, Indiana
E
E
South Bend, Indiana
Mine is a 69 I belive built Apirl or May,K-frame is about the only thing that has never been taken out of car.and I know it has it,will get a picture today.will post later.Bob also it's a slug not a washer
Re: Slug on my K-frame [Re: FJ5_Fish] #1364149
01/07/13 11:05 AM
01/07/13 11:05 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Here is the coin on my 69 Swinger 340.....no number stamped on it - just a blank coin.
Re: Slug on my K-frame [Re: FJ5_Fish] #1364150
01/07/13 11:07 AM
01/07/13 11:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Very interesting ...
Re: Slug on my K-frame [Re: Ellies Dart] #1364151
01/08/13 07:15 AM
01/08/13 07:15 AM
South Bend, Indiana
E
E
South Bend, Indiana
I thing this will work Slug..2nd pic 69 Dart Swinger 340 4-speed
Re: Slug on my K-frame [Re: Ellies Dart] #1364152
01/08/13 04:51 PM
01/08/13 04:51 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
My 69 cuda 340 has a washer , not a slug, welded on mine. it also has the reinforcement around the LCA holes.
Re: Slug on my K-frame [Re: 2abodymcodes] #1364153
01/08/13 05:02 PM
01/08/13 05:02 PM
Shelby, Ohio
2
Shelby, Ohio
the LCA reinforcement
Re: Slug on my K-frame [Re: 2abodymcodes] #1364154
01/08/13 07:46 PM
01/08/13 07:46 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
My 340 Duster has that slug also. So I went over and looked at my friends 69 340 Dart, it's there too. Must be a 340 thing.
Re: Slug on my K-frame [Re: bigblock340power] #1364155
01/08/13 07:53 PM
01/08/13 07:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Could you guys who have posted pics of K-members with slugs/washers please post the spd of your cars? Also the stamped in date code on the K-member and production plants if possible?
Thanks!
Re: Slug on my K-frame [Re: ScottSmith_Harms] #1364156
01/08/13 08:40 PM
01/08/13 08:40 PM
Shelby, Ohio
2
Shelby, Ohio
where would the date code be, and what is spd ?
