Please help! No oil pressure! #1364039
01/04/13 01:15 AM
01/04/13 01:15 AM
California
shamefulcuda Offline OP
California
Guys I just put 383 in my roadrunner. I bought a rebuilt engine from a Mopar guy never ran. Stuck it in but had excessive valve train noise. Took valve covers off and heads bone dry. I took off sending unit and primed motor w drill and oil comes out but does not shoot out like I'm used to. Put auto meter gauge on and pretty much reads 0. Bought new hv oil pump thinking it was just bad and still same result. I'm at a loss. We yanked oil pan and pickup looks new and is clear. Nothing obvious as we looked at oil pump passage where oil pump goes and everything seems fine. Everything in motor is brand new and I've been up and down it now. When I start it , sounded good from back end other than valve train. Makes me think lower end is getting oil. I'm clueless and at odds on what to do next. Any engine guys ever run into this? Need help fast
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364040
01/04/13 01:25 AM
01/04/13 01:25 AM
Need help fast
probably missing an oil gallery plug. Been on SB's for decades so I'm rusty on BB (but a 451 is in the works) but I think there's one under the timing cover & others will chime in with more info.
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364041
01/04/13 01:40 AM
01/04/13 01:40 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
You started the motor dry???? then tried to prime it? Could be an oil galley plug that was not put in. But it really should have been primed before start up...Try Rotating the motor over by hand to a different spot to prime it..
Re: Please help! No oil pressure! [Re: QuickBpBp] #1364042
01/04/13 01:55 AM
01/04/13 01:55 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You're running the drill counter-clockwise, right? And using a known-good gauge in one of the holes at the top rear of the block?
Re: Please help! No oil pressure! [Re: topside] #1364043
01/04/13 02:06 AM
01/04/13 02:06 AM
California
California
Primed til oil came out of sender and figured it was fine. Only after running did I realize problem. Put 2 different gauges on same result. Yes counter clockwise on drill. So galley plugs on front of motor? If I had it over again I would stick gauge on from beginning
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364044
01/04/13 02:13 AM
01/04/13 02:13 AM
Primed til oil came out of sender and figured it was fine. So galley plugs on front of motor?
If good it would have been a geyser. Yes there's a pipe plug behind the timing cover
Re: Please help! No oil pressure! [Re: RapidRobert] #1364045
01/04/13 02:39 AM
01/04/13 02:39 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I believe there are 2 plugs behind the timing cover - one on the front and one underneath the galley.
Re: Please help! No oil pressure! [Re: RapidRobert] #1364046
01/04/13 02:42 AM
01/04/13 02:42 AM
There are two oil galley plugs in the front of BB mopars, one behind the cam gear on the passenger side and one tucked under the cam gear pointed towards the oil pan on the drivers side Four in the back, two on top and two behind the flex plate or flywheel. If it had pressure to the rear of the block I would look at all the lifters to make sure there in, especially on the drivers side
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364047
01/04/13 02:44 AM
01/04/13 02:44 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Might be 3 total with one that faces down IIRC.
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364048
01/04/13 05:22 AM
01/04/13 05:22 AM
smyrna,tn
draginmopars Offline
smyrna,tn
do you have a bore scope?
You can remove the fuel pump and plate, and look in while priming the oil system.
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Please help! No oil pressure! [Re: draginmopars] #1364049
01/04/13 02:26 PM
01/04/13 02:26 PM
California
California
I had oil coming out in back but no actual pressure with gauge hooked up. Lets hope it's a front plug and not rear of motor behind flywheel as I have all my 4 speed stuff hooked up now. Do not want to tear apart whole motor obviously . I have no bore scope so I guess I'm tearing front of motor off today
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364050
01/04/13 02:34 PM
01/04/13 02:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think with the fuel pump out you could hear the oil escaping through a missing plug. You would just have to hacve a helper run the priming drill for you while you listened at the front.If a plug was missing at the rear of the engine you would have oil leaking out of the bell housing.
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364051
01/04/13 04:12 PM
01/04/13 04:12 PM
smyrna,tn
smyrna,tn
a mirror and flash light will work.
i always have to double check, the lower one
I left that one out MANY years ago, (in a 440 RV van) lesson learned
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364052
01/04/13 04:29 PM
01/04/13 04:29 PM
Check your oil pressure gauge with some air pressure first now I have had a valve spring break while racing,it broke on the return road idling back to the pits, and that let a pushrod fall out of the drivers side which allowed that roller lifter to pop out of its lifter bore, which resulted in either zero or less than 10 lbs of oil pressure, I can't remember now exactly what the gauge read when I looked at it, it was low so I shut it off right away. This problem has me intriqued Please let us kow what you find BTW, I have also had the bypass valve in the BB oil pumps stick half way open due to a tiny bit of debris being caught between the valve and oil pump passge it rides in, new motors make metal while breaking in I wouldn't think that is your case do to swapping ol pumps but is is easy to ceck, take the pump off the motor and remove the plug and spring that holds the bypass valve in and point the passage down toward s the bench, table or floor and see if it will side out using ravity. It will be slow to slide out do to the oil in there but it should slide out easily. If it has to be sucked out of there with a magnet or tapping the cover on a hard surafce check it, the valve, and the bore real carefully for burrs or debris Let us know what you find
Re: Please help! No oil pressure! [Re: QuickBpBp] #1364053
01/04/13 04:35 PM
01/04/13 04:35 PM
smyrna,tn
smyrna,tn
Is the pan still off, you can look for the plug from the bottom
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Please help! No oil pressure! [Re: Cab_Burge] #1364054
01/04/13 05:52 PM
01/04/13 05:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yes I would pull the valve covers if you already haven't
Re: Please help! No oil pressure! [Re: Cab_Burge] #1364055
01/04/13 06:07 PM
01/04/13 06:07 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
He already put a new HV pump on it with the same result...
Re: Please help! No oil pressure! [Re: QuickBpBp] #1364056
01/04/13 07:53 PM
01/04/13 07:53 PM
California
California
Guys thanks for your help. Front galley plug was missing. Put one on and back together and it runs perfect. Just got done banging through the gears finally. Feelin' good
Re: Please help! No oil pressure! [Re: shamefulcuda] #1364057
01/04/13 08:24 PM
01/04/13 08:24 PM
smyrna,tn
smyrna,tn
I would pull the rocker arm shafts and check them.
just to be sure there is no damage, from lack of oil.
hate to find out down the road.
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Please help! No oil pressure! [Re: draginmopars] #1364058
01/05/13 12:36 AM
01/05/13 12:36 AM
