Overheating at idle #136378
10/14/08 06:03 PM
10/14/08 06:03 PM
central PA
mopartial Offline OP
central PA
A-body, Fresh 318, RV cam, Perf intake, Eddy 650cfm, headers.
Runs fine. 190* when cruising. If left to idle (800rpm) for 5- 10 min temp climbs 240+.
I have JY 26" radiator that I had re-cored, no shroud. Stock fan, orig belt set-up. Std 180* thermostat, I think.
Why does it overheat at idle? Do I need a shroud?
If so, I may need rad/shroud from aftermkt, where should I look?
Thanks.
If it aint broke, dont break it.
Re: Overheating at idle [Re: mopartial] #136379
10/14/08 07:11 PM
10/14/08 07:11 PM
Shroud. correct fan spacing. possibly faster fan speed(ch pulleys).aftermarket water pump(w disc).
Re: Overheating at idle [Re: mopartial] #136380
10/14/08 07:45 PM
10/14/08 07:45 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
Does it have a fan clutch? That could be a problem too......
Re: Overheating at idle [Re: mopartial] #136381
10/14/08 07:48 PM
10/14/08 07:48 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
In any instance, a shroud and proper fan spacing should always be used but I'm concerned it's something else considering that it's jumping that far to over 240 in just 10 minutes time. My car responded well once I got the right fan and shroud, but it only helped me to run from 205 to 190, and that was a sloooow climb to 205 before the shroud.......
Re: Overheating at idle [Re: mopartial] #136382
10/15/08 01:31 AM
10/15/08 01:31 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
May not be your problem, but - Check the fan - I have seen more than one installed backward so it was trying to push air rather than pull.
Also improper timing can cause too much heat.
Open/remove the radiator cap while the motor is still cool. Check for water flow once thermostat opens. No flow, could be a bad thermostat (or bad pump). Which direction is it flowing - should be toward the lower hose (wrong pump or reversed impellers are rare but possible).
Use an infrared temp gun on the radiator to check for cold spots (blocked radiator). This also verifies the overheating is not just a bad gauge sending unit.
Scott
Re: Overheating at idle [Re: 68Bullit] #136383
10/15/08 07:07 AM
10/15/08 07:07 AM
