battery can freeze? #1363308
01/02/13 08:04 PM
01/02/13 08:04 PM
Indiana
rapid67rt Offline OP
Indiana
Truck wouldnt start so I took the battery out to charge it up. No luck so I took it back since it was still under warranty. Counter guy said it was frozen. It did get down into the single digits last night.
Ive never had this happen or ever heard of it. I had to raise hell to get it replaced.
Re: battery can freeze? [Re: rapid67rt] #1363309
01/02/13 08:16 PM
01/02/13 08:16 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
They will freeze if they're discharged.
It's Swifty! Swifty, you toad sucker!
Re: battery can freeze? [Re: zrxkawboy] #1363310
01/02/13 08:20 PM
01/02/13 08:20 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
my high school car wouldn't start one day in some extreme cold weather. at first, nothing. thought "great, battery's dead" but noticed the dome light was on. turned on headlights and they came on. thought "that's weird" and tried again. this time I got a slow moan out of the starter.
then tried again and it cranked faster but still no start.
third time, it fired right up.
best I can figure is that it was so cold that it didn't have enough amps, but as I was putting load on it and discharging power, that it warmed up enough to start making more amps until finally it was warm enough to start the engine.
am I right in my theory or not, I have no idea. all I know is what happened. it may have just been dumb luck.
**Photobucket sucks**
Re: battery can freeze? [Re: 70Cuda383] #1363311
01/02/13 08:32 PM
01/02/13 08:32 PM
Indiana
Indiana
Yea sounds similar. Is it just me.. but if batteries froze alot of vehicles would be down all winter?????I hope I didn't buy some China crap......
Re: battery can freeze? [Re: rapid67rt] #1363312
01/02/13 08:34 PM
01/02/13 08:34 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Like I said, they only freeze if they're discharged.
Re: battery can freeze? [Re: zrxkawboy] #1363313
01/02/13 08:37 PM
01/02/13 08:37 PM
Indiana
Indiana
School me please? Discharge? Is this a sign that its going bad??
Re: battery can freeze? [Re: 70Cuda383] #1363314
01/02/13 10:28 PM
01/02/13 10:28 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I don't know. I read somewhere that if it's cold enough to bring the brass monkeys in that before you try to start the car, turn the headlights on hi beam for about 15 seconds, shut them off, and then try to start. Sounds kind of like the same thing.
Re: battery can freeze? [Re: rapid67rt] #1363315
01/02/13 10:34 PM
01/02/13 10:34 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Could be a sign of a battery going bad, possibly a dead or dieing cell, could be corrosion on the terminals, or in the battery lead wires not allowing correct voltage flow to fully charge the battery, could also be a bad diode in the alternator, or sign of a bad voltage regulator.
A good once over and cleaning of the electrical connections to the battery and its accessories will help in diagnosing the exact cause.
If you have an amp gauge, or voltage gauge its readings should be telling you something. Or the ALT idiot light.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: battery can freeze? [Re: rapid67rt] #1363316
01/02/13 10:34 PM
01/02/13 10:34 PM
Kirkland, Washington
Pacnorthcuda Offline
When a flooded lead acid battery is discharged (dead) the electrolyte (acid) concentration is very weak (mostly water). Sulfuric acid has much lower freeze point than water.
That is why a dead (or very weak) batt can freeze.
Re: battery can freeze? [Re: Pacnorthcuda] #1363317
01/02/13 10:55 PM
01/02/13 10:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Back in my youth my Old Man used to bring his battery in at night so it wouldn't freeze. This was back up in NW Indiana in the early 70's FWIW.
Don't be the exception.
Re: battery can freeze? [Re: Supercuda] #1363318
01/02/13 11:45 PM
01/02/13 11:45 PM
Alberta
rustbuckett68 Offline
Alberta
My 64 F-100 with a worn out 223 6 would start at -40C (40 below 0). Didn't need to use the brakes for the first ten blocks, just hit the clutch. Couldn't shift the 4 gear, and had to use a lot of muscle to steer for the first bit. Figured out pretty quick that was no way to treat a vehicle, so stayed home until it warmed up to -29 (20 below 0).
Re: battery can freeze? [Re: Pacnorthcuda] #1363319
01/02/13 11:54 PM
01/02/13 11:54 PM
that's it & the counter guy thought you let it discharge way down & that's why he didn't want to warranty it
