Re: 440 tapped/knocked, then it disappeared [Re: p d'ro] #1362484
01/01/13 06:34 PM
01/01/13 06:34 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
How much does the oil pan hold? Does it have baffles or a windage tray?
Sheldon
Re: 440 tapped/knocked, then it disappeared [Re: p d'ro] #1362485
01/01/13 07:10 PM
01/01/13 07:10 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Tapping/thicking sounds are valvetrain related or headergasket leaks.
Knocking sounds are usualy bearing or sometimes piston-related.
IMO, the moment you hit fullthrottle on the engine from a dead stop is probably when the oil sloshed away from the oilpickup and could have deprived the oilsystem from have sufficient oil (and pressure).
I've had this happen before and my remedy was to overfill the engine by about 7/16" on the dipstick.
Do you have an oilpressure gauge installed? If not, install one rightaway.
As for oil replacement, look at the current oil pressure and decide if you want to go with a thicker or thinner oil.
I would say for a properly rebuild engine you should not need any oil thicker than 10w40 or even 10w30.
Re: 440 tapped/knocked, then it disappeared [Re: Dean_Kuzluzski] #1362486
01/01/13 08:12 PM
01/01/13 08:12 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
the other blew into 2 pieces when the fulcrum split. True story.
I've seen that happen before
Re: 440 tapped/knocked, then it disappeared [Re: GTX MATT] #1362487
01/02/13 09:57 AM
01/02/13 09:57 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Thanks guys. I do have a windage tray and baffles. I will change oil and slightly overfill, and try to do the other things. Does AutoZone carry the scopes? Is 5k rpm really too much? It was still pulling hard when I let off and shifted. I do have oil pressure guage and it is steady at 50 and above as usual and running at same temp.
Re: 440 tapped/knocked, then it disappeared [Re: p d'ro] #1362488
01/02/13 01:11 PM
01/02/13 01:11 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Harbor Freight has the bore scopes.
http://www.harborfreight.com/digital-inspection-camera-67979.html
I think they are on sale now for $69.99 in the current flyer. I was thinking about getting one...
Re: 440 tapped/knocked, then it disappeared [Re: p d'ro] #1362489
01/02/13 01:23 PM
01/02/13 01:23 PM
Myself I would have someone check preload unless it was a significant bang & it sounds like it was which would point to something more severe than the light clatter from preload. If you have 50lbs of oil psi then adding oil will not help it assuming that was it & I doubt it tho an oil gauge can read good but from the convoluted oil path the bearings can still be starved at times which is why oiling mods when going together are beneficial. Bore scopes are nice but pricey & if there was something in the combustion chamber you'd still hear it. After checking preload (if called for) I'd call it good & run it . 5K ain't excessive IF Piston to valve/Piston to head (quench)/adequate valve spring psi all good? EDIT I reread your OP & I think bad lifter(s)/preload/header leak on the mild tapping & the thud was something more serious/seperate
Re: 440 tapped/knocked, then it disappeared [Re: p d'ro] #1362490
01/02/13 03:30 PM
01/02/13 03:30 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
If it's an automatic, check your torque converter bolts.
Re: 440 tapped/knocked, then it disappeared [Re: Jwilli500] #1362491
01/02/13 09:31 PM
01/02/13 09:31 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
This is definitely worth a check, especially for the recent louder noise.
Personnally, I don't think its preload, as you would think 16 lifter would be making noise.
