Page 2 of 3 1 2 3
Re: 587 HP 360 [Re: pittsburghracer] #1361937
12/31/12 06:09 PM
12/31/12 06:09 PM
Washington
skrews Offline OP
skrews  Offline OP
Washington
I have to wonder about the Super Victor my self. It killed TQ under 4500 and I mean killed (30 or 35# campared to AirGap). I think it's a great intake in the right application ie circle track or 400+ ci drag. My little ci low comp motor can barely use it. Would like to try the AirGap with a 2" Wilson tapered spacer. In subsequent testing on my 440HP spare parts 360 the 2" Wilson was about 10HP better than the open 1" when run on the same AirGap intake. I believe the HP is legit, its just that its in a poor chassis for the engine combo. Put this in the more typical sub 3000LB car, with a good converter, trans brake, at a bit lower elevation track and it would move.
Re: 587 HP 360 [Re: skrews] #1361938
12/31/12 06:23 PM
12/31/12 06:23 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IMO for that engine a Weiand X-Celerator would be a great intake.
Re: 587 HP 360 [Re: skrews] #1361939
12/31/12 06:30 PM
12/31/12 06:30 PM
SoCal
Brian Hafliger Offline
SoCal
There are alot of things that can affect mph that's for sure. When I first started running my w2 headed 360 duster it went 119mph and made right at 500hp. Once I changed the alignment up front and ran more tire psi in the rear I gained 2mph!
So mph is not always an indicator but more like a guage that can be off once in a while.
I'll bet the SV intake is hurting gear changes.
Brian Hafliger
Re: 587 HP 360 [Re: justinp61] #1361940
12/31/12 06:33 PM
12/31/12 06:33 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
theres a guy with a 1972 340, cuda, FS/A, 3325#,stock intake, , carb, small valve heads, 9.0 cr, hydcam, ran 10.97 @ 120MPH. looking at charts, etc, this motor made 445 HP. according to same charts, 587 HP, @ 3200#, should run 9.97 @ 133 MPH. we have a friend with a 340 duster, full stock car, weighs 3345 with driver- 200# =3145.dyno must be very generous?????
Re: 587 HP 360 [Re: perfmachst] #1361941
12/31/12 07:08 PM
12/31/12 07:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Aren't they all. How many times on this site alone see GREAT dyno numbers and very disappointing track numbers.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 587 HP 360 [Re: pittsburghracer] #1361942
12/31/12 07:52 PM
12/31/12 07:52 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Is anyone else worried about the cast eagle crankshaft at those power levels? I know it's stock stroke and stronger than a 4" arm but still, my 4" eagle broke at under 480 hp. Didn't dyno that one but the 440 in the truck now made 485 and it's faster than the 408 was. Just concerned for you, would hate to see your testing cut short because of a crap crankshaft.
Re: 587 HP 360 [Re: dodgeboy11] #1361943
12/31/12 10:33 PM
12/31/12 10:33 PM
Washington
skrews Offline OP
skrews  Offline OP
Washington
Bought the crank years ago before the Eagle cast crank reputation was well known. 4" steel crank, and some 13.7 Wiseco pistons are in the works for the season after next.
Re: 587 HP 360 [Re: skrews] #1361944
01/01/13 10:15 AM
01/01/13 10:15 AM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
My 410 magnum made 581HP@ 6100. With a race weight of 3475lbs it ran 10.50s@125 with 3.91 gears,28" tire and a 4800 stall. So I think you're leaving something on the table.
Tom
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: 587 HP 360 [Re: dodgeboy11] #1361945
01/02/13 11:47 AM
01/02/13 11:47 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I was thinking the same...for stock stroke, why go with a suspect chinese eagle cast crank over a stocker?
2017 Grand Cherokee Overland
Re: 587 HP 360 [Re: pittsburghracer] #1361946
01/02/13 12:14 PM
01/02/13 12:14 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Only the timeslips matter.
Re: 587 HP 360 [Re: Duner] #1361947
01/02/13 01:15 PM
01/02/13 01:15 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I agree the vert seems to be holding that great combo back quite a bit, you need more stall/flash....so long as you don't loose too much top end efficiency in the process.
The cam has a lot of lift for the .050 duration, are you running higher than a 1.6:1 rocker to get there?
Your thread is also very telling about the Eddie airgap, I can see that the cross section becomes a restriction to the torque peak which in turn lowers the hp trajectory in a predicable manner....great stuff and very telling info. you can sometimes only discover this on dyno tests where you have plenty of head flow and cam (i.e., proportional to the motor size) to get there to find the bottleneck.
I'd be tempted to run the Victor 340 on it to get another good side by side, the SV will help a 360 more so than a 408 I think since the SV runners are longer and the stroke of the 360 is shorter. The opposite tends to be true when the stroke is long the motor doesn't need additional runner length (for a given X-section) to make adequate mid range torque and the longer runner will then tend to be a gradual restriction above the VE/torque Peak.
WIZE
In Car:
Re: 587 HP 360 [Re: Duner] #1361948
01/02/13 02:11 PM
01/02/13 02:11 PM
SoCal
SoCal
Well yes and no...if you have a certain amount of power from dyno testing, you have data!
Now you take that, and then compare to the track data....yes it can be a dyno that is generous, but if you start looking at the WHY this and that you may discover problems or areas that need attention.
I agree if mph is low, there's a power issue possibly but WHAT is the issue? Not enough fuel delivery, spark, what changed from the dyno???
Type of fuel, timing, jetting, spacers?
Is the converter garbage allowing 500 or more rpm through the traps than should be? There should be alot of data to look through and compare with other racers to maybe find the problems if there are any.
Just my observation I guess...
Brian Hafliger
Re: 587 HP 360 [Re: Brian Hafliger] #1361949
01/02/13 02:19 PM
01/02/13 02:19 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
That's true.
The dyno is very good at providing data, but sometimes it doesn't translate directly to a perfectly matching result at the track is all I meant. Especially since some dyno's are stingy and some are generous. I use the dyno to figure out what's wrong with my heap when I can't figure it out on the track. It IS VERY helpful there. My last trip to the dyno showed me that I needed to try something else that I couldn't tell from the timeslip. So yes, they are a benefit and provide data.. but I still want that timeslip!
Re: 587 HP 360 [Re: Duner] #1361950
01/02/13 03:52 PM
01/02/13 03:52 PM
Guitar Jones Offline
I'm sure 590 or 600 HP is very doable from a 360. We'll see, since I've scattered the 408 I may just freshen the old 360 and go back at it. But I'm thinking a 4.86 or 5.13 gear at that weight and that short of a tire. I doubt the converter is holding it back unless it has a lot of slip on the top end. The stall speed is fine IMO. I run a 4200 in my car and it works fine. The 360 makes more torque down low than a shorter stroke 340 would.
Re: 587 HP 360 [Re: Guitar Jones] #1361951
01/02/13 05:24 PM
01/02/13 05:24 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Just looking at your Dyno shot that long "bundle of Snakes" of headers might be too long of a primary length to be optimum for the rest of the combo....maybe
WIZE
In Car:
Re: 587 HP 360 [Re: Streetwize] #1361952
01/02/13 07:43 PM
01/02/13 07:43 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: 587 HP 360 [Re: 65signet] #1361953
01/02/13 08:18 PM
01/02/13 08:18 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Awesome of you to share your combo and listen to the criticism on it! definitely helps guys like me learn something hearing all the different perspectives on how to cut the cake
I will say though that I still think your car runs HARD for what it is, regardless of whether or not there is the opinion it leaves something on the table...Thats only 10:1 compression and 365ci in a 3400lb car going high tens!!! I love it
Re: 587 HP 360 [Re: Duner] #1361954
01/02/13 08:24 PM
01/02/13 08:24 PM
SoCal
SoCal
That's true.
I concour!
Brian Hafliger
Re: 587 HP 360 [Re: patrick] #1361955
01/03/13 05:26 AM
01/03/13 05:26 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
At the time the Eagle crank was cheaper than having a stocker sent out for crack check, stroke equalizing, and indexing. As I said earlier this was before the Eagle cast crank reputation was well known. Would not buy a cast Eagle crank again. Thinking I might just tear this thing down and do the 4" steel crank. Don't want to ventilate the pan.
Re: 587 HP 360 [Re: Streetwize] #1361956
01/03/13 05:52 AM
01/03/13 05:52 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
1.6 rockers intake/exhaust. I wish I had a few other intakes to try when it was on the dyno. M1, Victor, Xcelerator would all have been interesting to try. Keep us posted on the AirWolf 220 headed beast. Wish those had been around when I bought the IndyBrocks.
Page 2 of 3 1 2 3
