3 Speed To 4 Speed
#1359941
12/27/12 10:43 PM
12/27/12 10:43 PM
Posts: 653 Fort Worth, TX
Dago Red
Fort Worth, TX
I only have one stick car and it's already a 4 speed. A local garage owner is helping his cousin upgrade a 71 Duster. Nice car. A s/b stroker and an 8 3/4 but it has a three speed (floor mounted) How difficult to change over to a tried and true Ma Mopar 4 speed and what parts will they need? (A clutch and new flywheel will be necessary too) These guys a mechanically sharp, they just haven't done any early Mopar stuff. They even tossed out a Chevy guy who bad-mouthed the build. Ya gotta like that! Pretty please, don't launch into a sales pitch about aftermarket 5 speeds or overdrive automatics. I'm asking here because this is where the sharp razors hang out. Thanks in advance.
If You Can't Be Good, At Least Be Colorful
Re: 3 Speed To 4 Speed
[Re: Dago Red]
#1359942
12/27/12 11:03 PM
12/27/12 11:03 PM
Posts: 4,285 Ohio
64dodge572
Ohio
If it is a V8 3-speed, all you would need is the 4-speed, shifter & linkage, as the bellhousing will be dual bolt pattern to accept either transmission. We can supply whatever you need.
Wayne
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: ScottSmith_Harms]
#1359944
12/28/12 07:58 AM
12/28/12 07:58 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Scott I think Hurst made one.I have a 3 speed that someone stuck in the 65 B sedan I had.It has a Hurst shifter.Seems to be a tight shifter.Been sitting on the garage floor for probally 10 years.Seem no one wants 3 speed trannys.Rocky
Chrysler Firepower
[Re: 64dodge572]
#1359945
12/28/12 12:42 PM
12/28/12 12:42 PM
Dago Red
Fort Worth, TX
Wayne is the 4 speed an improvement, strength wise, or is the 3 speed stout enough? It seems unusual to me to have a 340 A-body with an 8 3/4 with a 3 speed between the pair.
[Re: Rhinodart]
#1359949
12/28/12 01:27 PM
12/28/12 01:27 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Scott--no, there is no Hurst replacement shifter for the 3-speed available, I am sure there was years ago, but since Hurst was purchased by B & M there is no info available on a part number to go by to possibly find a NOS package somewhere. The 4-speed would be an improvement over the 3-speed, better splits and stronger, although the A230 3-speeds were pretty tough as well.
Wayne
#1359951
12/28/12 01:37 PM
12/28/12 01:37 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Yea that's what I thought Wayne but figured if one existed you'd know about it. Keep me in mind if you stumble accross anything I can use. I am going to run a Passon 5 speed eventually but I need to get my car put together so while I'm waiting I'm gonna run the 3 speed because that was what originally came in it.
*Have you noticed any differences between the shifter mech/shifter/linkage setups for a /6 3 speed trans and a v8 3 speed trans? Speaking 1970-71 A-body.
Scott--No, its the same crap. Wayne
[Re: 64dodge572]
#1359952
12/28/12 01:50 PM
12/28/12 01:50 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
If you do change to the 4 speed The drive line is going to need to be shortened.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: Rhinodart]
#1359953
12/28/12 11:25 PM
12/28/12 11:25 PM
Posts: 511 AZ.
696pack
AZ.
A friend in high school had a brother who owned a 71 Demon with a 340, 3-speed, and 3.91 gears, it was the quickest street package in town! Stoplight to stoplight he couldn't be beat! I thing the combination of the 3-speed gear spacing and the 3.91's was ideal.
The three speed has a good gear spread for racing. We sold a new 70 340 Challenger (A66) with that 3 speed and it hauled the mail through the 1/4.
[Re: Dago Red]
#1359956
12/29/12 12:18 PM
12/29/12 12:18 PM
It was actually pretty common, as the 3-speed didn't get an insurance surcharge like the 4-speed did.
No, I've done this conversion a couple of times; the (all-synchro) three-speed manual trans is the same length as the 4-speed manual, so the driveshaft length is the same. As I recall, you do have to change the front yoke, though, as the 3-speed has a 904 sized/splined output shaft, while almost all 4-speeds have the 727 sized/splined output shaft.
[Re: Supercuda]
#1359957
12/29/12 08:41 PM
12/29/12 08:41 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
It shouldn't need shortening with an A body A833. Maybe a different yoke though, depending on the A833 in question. [/quote
I agree, did the 3 speed to 4 speed swap in a 71 Demon with a 318, all that was needed was a different yoke.
