Front or Rear Caliper Mount?? #1359827
12/27/12 03:37 PM
12/27/12 03:37 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
65 Coronet with A body Spindle with 11 Rotor, Slider Calipers.
I have them rear mounted.
Will front mount improve braking?
I dont have a sway bar on this car but would consider install. Will it be a problem?
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359828
12/27/12 03:43 PM
12/27/12 03:43 PM
AndyF Offline
AndyF  Offline
No change in braking performance but the hose routing is easier with the calipers mounted to the front. Rear hung calipers are more difficult to plumb since there isn't very much room for the hose.
Re: Front or Rear Caliper Mount?? [Re: AndyF] #1359829
12/27/12 04:27 PM
12/27/12 04:27 PM
DC, MD Suburbs
DC, MD Suburbs
Just drove the 65 Coronet. Lackluster braking. I had a locking up condition due to pushrod adjustment at first. Pads must be glazed.
Lock up fixed.
I posted yesterday about pads. I ordered the last set of Bendix Titanium Metallic II's from Rock.
Car has 1 1/8 Manual Master sourced from E-Burg, 69 Coronet Drum Distribution block, 74 up 11 Inch Sliders with organic pads, Rear Line Prop Valve and 10*2 rear shoes.
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359830
12/27/12 04:50 PM
12/27/12 04:50 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Your front brake package is done similar to mine...I think the lackluster part begins with the distibution block for drum brakes.
...FAFO...
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359831
12/27/12 05:32 PM
12/27/12 05:32 PM
AndyF Offline
AndyF  Offline
Brake effort will be high with the large diameter master cylinder. So you'll need to stand on the pedal to get the car to stop. If you want a lower pedal effort and don't mind more pedal travel then swap to a smaller bore size in the master cylinder.
The drum distribution block with a rear mounted prop valve should work just fine. That is a standard way to go when retrofitting an older car. My '65 is set up the same way.
Only thing you should double check is your caliper mounting. If you rear mounted a set of front mounted calipers then you might have installed them upside down. People do that all the time and then they can't figure out why the brakes don't work very well. The bleeder needs to be at the very top of the caliper so that air can escape.
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359832
12/27/12 05:54 PM
12/27/12 05:54 PM
As said no, If you're going together ideally you'd want the calipers on the opposite side (front or rear) of the spindle as the hard line/hose mounting tab is so in other words the hose has to go horizontally behind/past the spindle to go from the caliper to reach the tab. If you are already up & running as is sounds like you are then if you have the right hose that does not bind/rub/kink from lock to lock or up/down in the suspensions' travel you're set. On my 65 Dart I mistakenly put the calipers on the rear & I needed to bend the front section of those particular hoses that is a hard line to get it all to clear. EDIT '74 A discs
Re: Front or Rear Caliper Mount?? [Re: RapidRobert] #1359833
12/27/12 06:35 PM
12/27/12 06:35 PM
DC, MD Suburbs
DC, MD Suburbs
Car is up and running. I used the bigget bore cylinder for disc drum. This is the 10-1860 1981 D150 cylinder.
The bleeders are pointing up. Been there, done that! LOL
I will try the pad swap and if no success, try the longer stroke, smaller bore, MD. Recommendations?
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359834
12/27/12 07:46 PM
12/27/12 07:46 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
If you have a feeling the brakes just don't grab hard enough, you should go to a smaller diameter MC.
(Why did you choose the largest?)
I think you'll end up with a 15/16" or 1-1/32" MC in the end.
Was/is this a manual or power braked car?
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359835
12/27/12 11:12 PM
12/27/12 11:12 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I did pretty much the same swap on a 64 Belvedere wagon. I used A-body spindles with the calipers front mounted, A-body proportioning valve,11.75 rotors with pin type caliper adapters and calipers and hoses from a 70 Roadrunner.I used a NEW master cylinder for a 70 Roadrunner with power disc brakes. I cut 2 small notches in the bottom of my k frame, and used a sway bar from a 70 Roadrunner...and also the lower control arms from a 70 Roadrunner. Can you tell I had a 70 Roadrunner parts car? My wagon was a factory power drum brake car, is why I went with the power master cylinder, and the Roadrunner master cyl bolted right up. That behemouth would stop on a dime and give you nine cents change after the swap! Good luck.
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359836
12/27/12 11:36 PM
12/27/12 11:36 PM
Did you verify that the new master cylinder had the residual pressure valve removed for the front disc brakes? If not, do that
Re: Front or Rear Caliper Mount?? [Re: BigBlockMopar] #1359837
12/27/12 11:43 PM
12/27/12 11:43 PM
DC, MD Suburbs
DC, MD Suburbs
Manual brake conversion....
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359838
12/27/12 11:48 PM
12/27/12 11:48 PM
DC, MD Suburbs
DC, MD Suburbs
Would the 81 mc not be valved properly for disc/drum?
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359839
12/27/12 11:51 PM
12/27/12 11:51 PM
I've heard some weird storys about some of the later model Mopar M.C. Pull the little brass plug out of the port feeding your front brakes and see if that little rascal is in there or not
Re: Front or Rear Caliper Mount?? [Re: Cab_Burge] #1359840
12/28/12 12:24 AM
12/28/12 12:24 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This is a case where bigger is definitely NOT better. As Andy said, the larger bore increases pedal effort. You're using a 1.125" bore, swap to a 1.03" and it will take much less effort on your part.
Re: Front or Rear Caliper Mount?? [Re: Cab_Burge] #1359841
12/28/12 12:27 AM
12/28/12 12:27 AM
DC, MD Suburbs
DC, MD Suburbs
Run a screw in it and pry? Ideas
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359842
12/28/12 12:39 AM
12/28/12 12:39 AM
DC, MD Suburbs
DC, MD Suburbs
Pads have shipped. Will try those. Prob get an Advance smaller bore also.
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359843
12/28/12 01:04 AM
12/28/12 01:04 AM
stick a drill bit deep into the brass cone seat & if it has a RPV you'll feel its' springiness as it is only a piece of neoprene on a spring.
Re: Front or Rear Caliper Mount?? [Re: RapidRobert] #1359844
12/28/12 01:11 AM
12/28/12 01:11 AM
DC, MD Suburbs
DC, MD Suburbs
Anyone havebthe application ofbthe smaller bore (alleged) disc/drum master? Thanks
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359845
12/28/12 11:59 AM
12/28/12 11:59 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I just bought one at the parts store yesterday. The application I used was a 74 Dart. The power disk/drum master had a 15/16" bore (actually 31/32"- I guess they may hone them when they reman them???) The manual disc/drum master cylinder had a larger bore. So, I got the power master. And yes, it had the recess for the retainer.
This is the one I got:
http://www.oreillyauto.com/site/c/detail...2&ppt=C0066
Re: Front or Rear Caliper Mount?? [Re: mopowers] #1359846
12/30/12 10:27 AM
12/30/12 10:27 AM
DC, MD Suburbs
DC, MD Suburbs
Did a bot more research...Will check my Caliper Piston size. I assume they may be the smaller 74 Dart Calipers.
I see 78 Diplomat is about .10" larger.
Any one know the application of the smaller Rear wheel cylinder?
