Re: Measuring Pinion Bearing Preload??? [Re: fastmark] #1359822
01/01/13 04:07 AM
01/01/13 04:07 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Measuring Pinion Bearing Preload??? [Re: Mick70RR] #1359823
01/01/13 09:38 AM
01/01/13 09:38 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I have never done it on an automotive differential,
but on the bearing assemblies of large industrial pumps,
you measure the "breakaway torque"
with a conventional torque wrench,
but measure the "turning torque"
by wrapping several turns of strong fishing line around the shaft,
tie the loose end of the line to a hand held scale like a fishing scale,
then smoothly begin pulling the scale and line taut to get the shaft turning at a steady rpm.
Multiply the pounds of tension shown on the scale
by half the diameter of the pump shaft
and the result is the
inch-lbs of turning torque.
If a hand held scale is accurate,
and pulls against a wrench handle
at a right angle,
it is just as accurate as a torque wrench,
But this method
(And a conventional torque wrench)
Relies upon everything being stopped or steady
at the point of measurement,
because if there is any moving you have at least friction,
or worse, acceleration
which creates its own inertial force.
