Re: Oil Experimenting [Re: Sb Valiant] #1359302
12/27/12 08:57 PM
12/27/12 08:57 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
At that time it had a 9.5' converter in it. I bought a 8'race converter from PTC and it ran a 7.32 @ 92. The crate motor that was in it at the time was 9 to 1 comp., stock magnum heads, .501/ .513 lift hydraulic roller cam and 1 5/8 block hugger headers. The 9.5 converter foot brake stalled about 2600 rpm.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Oil Experimenting [Re: Sb Valiant] #1359303
12/28/12 12:23 AM
12/28/12 12:23 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Well, change the converter, rather than worrying about the oil you're running
Alan Jones
Re: Oil Experimenting [Re: LA360] #1359304
12/28/12 01:21 AM
12/28/12 01:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
To be honest I wouldnt change the conv YET.... seems
like he is constantly changing things... I would
set the timing at say 34* and set the carb so its
not real lean and run it for the weekend to test
some other things(just checking things NOT changing
anything) and see how the conv acts and if its constant...
I would be checking fuel pressure going down the track
(a gauge I can see) and start eliminating things...
I hate seeing people just start throwing parts at a car
Re: Oil Experimenting [Re: MR_P_BODY] #1359305
12/28/12 05:56 PM
12/28/12 05:56 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
You must have a pretty mismatched combo. My 67 Barracuda HT with 915 heads that I ported, 265 @.050 with .620 lift cam, 4.30 gears and 28X10 MT slicks and a 4200 stall converter ran between 6.99 and 7.04 at 95MPH in the 1/8 Maybe you don't have enough compression. What is your 60' time? Maybe I am comparing apples to oranges if the red PU is you car. Anyway I would think that with the stall you have it should be 1.65 or less 60' if it has bite and torque.
Re: Oil Experimenting [Re: MR_P_BODY] #1359306
12/28/12 07:50 PM
12/28/12 07:50 PM
LA360 Offline
LA360  Offline
You do make a very good point Mike
Alan Jones
