Re: welding trunk floor?
[Re: Clanton]
#1356078
01/07/13 03:45 PM
01/07/13 03:45 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
Meeeeeeeeeeeeeeeeeemories....Looks good...Throw a vinyl trunk mat and no one will see a thing
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Clanton]
#1356079
01/07/13 03:51 PM
01/07/13 03:51 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
That is great for aluminum but you should run 75/25 for steel. Tim Quote:
I am using 100% argon.I have to check the wire but it is .023 I think.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Pyper70]
#1356080
01/07/13 05:04 PM
01/07/13 05:04 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I have a 8gal fuel cell to mount as well as a battery later but I could still have some mat in there. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Clanton]
#1356081
01/07/13 06:51 PM
01/07/13 06:51 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Strangely most people with toy welders end up with argon. And that seems to be what most of the places that sell them pimp. A buddy of mine was whining his welder wasn't working and when I asked what gas he was using he said argon. My immediate response was that he got the wrong stuff but I decided to check the 'net. If you look at Praxair's website, they recommend argon for thin steel (sheetmetal) only as well as aluminum. As it turns out his problems were due to rusty wire and when we got that straightened out I tried the argon on thin stuff. I didn't care for it at all but then I'm used to a CO2/argon mix. If the plan is to weld anything thicker than sheet metal then you want to switch to a mixed gas. Praxair's "autoweld" is a good mix for bodywork and heavy stuff.
