Is this Exhaust valve ok to use?
#1355244
12/18/12 09:45 PM
12/18/12 09:45 PM
Posts: 958 eastern, pa.
cudabitten
eastern, pa.
Hey, Just cleaning up my 360 heads. Putting in new springs with the cam/lifter kit. The intake valves look real good, but the exhaust valves do have some wear. Do you think these will be ok? I'd rather use them if I can. What about using a valve lapping kit on them?
Re: Is this Exhaust valve ok to use?
[Re: MoparforLife]
#1355249
12/18/12 11:24 PM
12/18/12 11:24 PM
Posts: 4,799 ILL
MLR426
ILL
Take the heads to a decent machine shop and get a valve job done they need it. Also your NEW valve springs need the installed height corrected and have the guides checked. Their is no good reason to go through all the work without doing the job right.
MLR426
[Re: Cab_Burge]
#1355252
12/19/12 11:09 PM
12/19/12 11:09 PM
Posts: 4,799 ILL
MLR426
ILL
Yes grind the valves and the shop should use a 30 degree top angle and narrow the seat up and move it slightly up the angle of the valve to save the valve and extra cost to replace it.
MLR426
