Page 6 of 180 1 2 4 5 6 7 8 179 180
Re: Real world weight loss program and it` cost.......... [Re: 493_DART] #1353286
12/21/12 04:28 PM
12/21/12 04:28 PM
State of confusion
Thumperdart Offline OP
State of confusion
The rear windows are some what gutted now but definately want to do all side glass in lexan and remove more material while I`m there.....
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353287
12/21/12 07:36 PM
12/21/12 07:36 PM
fullmetaljacket Offline
for all of those DRUMMER boys still out there. The flat smooth rounded replacement drums from Wagner are a pound and half lighter than the factory finned drums made to cool off the brakes more.
That is rotating weight cut off where it can really help.
Re: Real world weight loss program and it` cost.......... [Re: topbrent] #1353288
12/21/12 08:23 PM
12/21/12 08:23 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Here is some of Ron Silva's lightening efforts on his old Valiant.
Here is a bumper bracket.
Damn...
*Running off to garage with hole saw in hand*
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353289
12/28/12 12:13 AM
12/28/12 12:13 AM
State of confusion
State of confusion
Man, this is a lot of work especially with a cut-off wheel and a sawzall. Havn`t messed w/the plasma cutter but sure have been wearing out sawzall blades and after removing the rear windows(will be lexan),cutting out all metel behind the ft. and rear windows and excess trunk material and all interior and trunk carpet plus one battery we`re right around a 100 lbs. using a bathroom scale. I can replace the whole trunk floor w/alum. if need be to start fresh and fix my "patch" job I did years ago and still havn`t removed the ft. door windows and wind wings but I will have to put some back of course w/the carpet(no padding)and lexan which shouldn`t be much I hope. Really considering the dash area now and the steering colum for more removal but the plasma cutters going to be needed there.........THANKXXX FOR THE TIPS............
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353290
12/28/12 12:33 AM
12/28/12 12:33 AM
Don't worry so much, the work has just started to get interesting. Try and see how much those little micro cut off wheels for the Dremel tools cost and than you'll really cry the blues.
I'll send you'll a flick of my STOCK steering column when I return back home from Detroit.
You'll know that I'm out here up to no good. LOL.
Be liberal in your metal removal on the back end because of the importance of structural integrity there by the quarters. I usually like to focus the heavy/any removal from the B-pillar towards the front of the car, doors included.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353291
12/28/12 12:44 AM
12/28/12 12:44 AM
State of confusion
State of confusion
I know weight in the rear is good to a point but I can still get a glass bumper and deck lid and I`d bet there`s maybe 35-40 lbs. no? The ft. is where it gets tricky like firewall foreward so not sure what I can do there............ Thankxxx again.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353292
12/28/12 01:24 PM
12/28/12 01:24 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
looking at these posts. looking good! but what happen to ron Silva?
i havent been here in awhile....is he ok? did he sell or crash is his car?
wasnt he building a 500 inch small block?
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353293
12/28/12 01:29 PM
12/28/12 01:29 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
what brakes are you running? alot of weight there in the stock stuff
Re: Real world weight loss program and it` cost.......... [Re: 70blackfish] #1353294
12/28/12 05:03 PM
12/28/12 05:03 PM
State of confusion
State of confusion
Wilwoods up ft. and stock drums in the rear. Ron`s fine just got a bit riled when some questioned him and who knows what else about the 500 incher he was building.........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353295
12/28/12 05:30 PM
12/28/12 05:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I went from 11 X 2 rear drums to Wilwoods with the parking brake and lost 16 pounds. I did something similar to ron on the front bumper brackets and lost 5.6 pounds. I lost over 4 pounds just by going to an aluminum master cylinder.
Ron had his 500" small block for sale the last time I had contact with him, nice guy .
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353296
12/28/12 09:22 PM
12/28/12 09:22 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
When everything else is cut out/off/removed...
http://www.racebolt.com/
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Real world weight loss program and it` cost.......... [Re: Adobedude] #1353297
12/28/12 09:39 PM
12/28/12 09:39 PM
State of confusion
State of confusion
I`ll keep that place in mind but was going to first try local shops and see about alum. bolts/nuts for everything that I can replace em with w/out affecting strength...........I`m on a mission now and there`s no turning back...........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353298
12/28/12 11:56 PM
12/28/12 11:56 PM
Dominic, do not forget the NHRA rule about stock firewall and floorboards, other than wheel tubs. If you add aluminum floor and or firewall the car must have a full cage Forget what I just said, you've already ran way under 9.99 witha roll bar so why would they make you get a cage with aluminum floors and firewall
BTW, it sounds to me like you need more work to do to keep you busy
Re: Real world weight loss program and it` cost.......... [Re: Cab_Burge] #1353299
12/29/12 01:30 AM
12/29/12 01:30 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I can appreciate what you are doing to your car; I have been there and done that.
I would no longer work that hard, or spend that much time or money on a car that had served me as well as well as your car has served you. You will eventually reach a point of no return and it will become a gutted race car that still won't be as light, or as right as you would like it to be.
There are plenty of well engineered, light weight, proven cars out there that can be bought for 10 to 30 cents on the dollar. I know that you might think that it is somebody elses ride; but you could buy a complete car that needs nothing but required updates cheap. Just add your drivetrain.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353300
12/29/12 02:06 AM
12/29/12 02:06 AM
STOCK steering column.
A friend of mine spun this for me.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353301
12/29/12 02:08 AM
12/29/12 02:08 AM
Head to toe.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353302
12/29/12 06:57 AM
12/29/12 06:57 AM
State of confusion
State of confusion
Head to toe.
I want one...........how much? seriously...... I can appreciate what your saying Racealittle but I`ve had this car since 93 and it`s come a long way and I`m nowhere near done and want my 9.50`s then MAYBE I`ll cage it but it`s a street car that I race once in a while and I turned it into what it is and plan on keeping it that way. Now, if I could find a caged certed roller than maybe but even being offered $20,000 for my car I said no cos I can`t build one for that...............peace!
Re: Real world weight loss program and it` cost.......... [Re: Cab_Burge] #1353303
12/29/12 07:07 AM
12/29/12 07:07 AM
State of confusion
State of confusion
Cab, I`m not doing much more at this point except for ft. and side lexan and a bit of trimming on the steering colum and the dash unless I can get a glass or light weight dash............. Tired of going slow.........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353304
12/29/12 12:41 PM
12/29/12 12:41 PM
Had it spun like 8 years back. I than made the copy over of the trimming, notching, tapped holes and all using a stock steel column. Saved about 3-1/2 lbs.
Material and spinning cost me 100.00 but I don't think he is in the same place anymore and the cost have probably gone up since.
Re: Real world weight loss program and it` cost.......... [Re: racealittle] #1353305
12/29/12 12:49 PM
12/29/12 12:49 PM
Some cars have too much pure personal investment in them and have developed their own characters that only the owner knows through thick and thin.
I could not rebuild my car as it is today with today's dollars. It all came through years of bartering, favors and inventing. A gret journey indeed.
I see many 65'at shows, cruises and the races, including real A990's and none have the stance and character that my street thug has.
