Diamond's Compression Ratio Calculator #'s #1352372
12/16/12 12:44 AM
12/16/12 12:44 AM
Raleigh, NC
Meangreen68 Offline OP
Raleigh, NC
I gathered what firm numbers I have for my engine build and plugged them into Dimaond's compression calculator.
But when it comes to the Fel Pro 1009 head gasket's bore diameter, the hole doesn't look very round in my gaskets.
4.35" bore
3.91" stroke
6.89" rod
~4.39" average head gasket bore diameter
~.037" compressed gasket thickness
10.7109" deck height
.24" from top of 1st ring to top of piston
84cc Edelbrock head chamber volume
4cc valve relief in top of flat-top piston
.0009" distance from top of block to top of piston in hole
1.865" piston CH
10.68 to 1 was the result.
Would the Cometic 4.350" or 4.380" x .036" gaskets be a better option? the compression rises to 10.72/71 with those numbers.
Would the 4.350" bore gasket would be too tight?
Or would you just stick with the Fel Pros?
http://www.diamondracing.net/tools/
Re: Diamond's Compression Ratio Calculator #'s [Re: Meangreen68] #1352373
12/16/12 01:31 AM
12/16/12 01:31 AM
10.68 to 10.72 is very little gain. I would consider a .030 gasket to get .039 quench keeping in mind PV clearance will need to be checked/dealt with if inadequate. A 4.35" bore gasket would be too small
Re: Diamond's Compression Ratio Calculator #'s [Re: RapidRobert] #1352374
12/16/12 01:56 AM
12/16/12 01:56 AM
Raleigh, NC
Raleigh, NC
Thanks Rob, but the piston is in the hole .0009", almost flush.
Wouldn't an .030" gasket make it .0309" quench distance?
Calculating-in an .030" gasket would bring the compression up to 10.85 to 1.
Re: Diamond's Compression Ratio Calculator #'s [Re: Meangreen68] #1352375
12/16/12 02:01 AM
12/16/12 02:01 AM
Correct, I missed that extra zero
Re: Diamond's Compression Ratio Calculator #'s [Re: Meangreen68] #1352376
12/16/12 03:12 PM
12/16/12 03:12 PM
.030 is to close for piston to head clearance, rock the pistons so you get the max. hieght at the cam side and then the motor mount side, make it have at least .035 clearance if you don't want the pistons hitting the heads, .040 is a lot safer on pump gas with a street motor
Re: Diamond's Compression Ratio Calculator #'s [Re: Cab_Burge] #1352377
12/16/12 03:58 PM
12/16/12 03:58 PM
Raleigh, NC
Raleigh, NC
Thanks Cab.
Cometic MLS gaskets are on sale for $79 each at the moment (4.380" x .036", bringing the quench to .0369").
Would you choose the Cometic's over the Fel Pro 1009's?
Re: Diamond's Compression Ratio Calculator #'s [Re: Meangreen68] #1352378
12/16/12 06:49 PM
12/16/12 06:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks Cab.
The surface of the head and the deck have to be a certian RA finish to use a Cometic .... if I have read threads about them correctly.
Re: Diamond's Compression Ratio Calculator #'s [Re: JohnRR] #1352379
12/16/12 07:56 PM
12/16/12 07:56 PM
Raleigh, NC
Raleigh, NC
Thanks John.
No telling what the finish is.
I still have pictures of the block being machined by CRE, but I wouldn't know what cutter was used on their Rottler F-65.
I must say, Mike was very meticulous.
