Power Disc Brake Problems #135190
10/11/08 06:57 PM
10/11/08 06:57 PM
Lowell Mi
Rat_Exterminator Offline OP
Lowell Mi
Hello, having brake problems with 70 300 Hurst I drove 1800 miles from Montana to Mich. Brakes were excellent until I got back. Pedal now sometimes goes to floor and brake light comes on. Checked vacumm at distributer, have about 12" at idle, brakes seem to be better at higher RPM, pulled master cylinder cover, front side full to overflowing(almost) and rear is two thirds empty. haven't added any fluid yet. This thing has so many vacumm lines running everywhere, pulled a couple off checking but that didn't seem to affect the 12" (at what I would consider to be a high idle). This is not the original motor or carb but everything as far as accessories appear to be in place and proper. At times car seems to idle really high 1250-1500? other times it idles about 900. Just trying to get the brakes sorted out so I can drive it a couple years until I get to restoring it, (paint and engine rebuild). Any suggestions on where to check vacumm at, I really think that has to be the problem. Brake fluid low but not out. Thanks Greg
Re: Power Disc Brake Problems [Re: Rat_Exterminator] #135191
10/11/08 07:17 PM
10/11/08 07:17 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Vacuum is not your problem when the brake pedal goes to the floor. Sounds like you have a fluid leak and/or your master cylinder is going bad. The missing fluid is what you should be chasing...
Re: Power Disc Brake Problems [Re: Lefty] #135192
10/11/08 09:59 PM
10/11/08 09:59 PM
Lowell Mi
Lowell Mi
I thought the reservoir would have to be empty before you'd see a problem. I'd never checked it when I left Montana. Rear, larger reservoir is for rear brakes? Seems like you'd barely notice the problem since front discs do 75% of the braking?
Re: Power Disc Brake Problems [Re: Rat_Exterminator] #135193
10/11/08 11:09 PM
10/11/08 11:09 PM
Andrewh Offline
Andrewh  Offline
rear resivoir is for the front brakes.
It sounds like your mc is bleeding by internally.
It is pushing fluid from the rear to the front of the mc. That is why you have extra fluid there.
I would also be concerned about it being sucked into the booster and then leaking along the firewall.
No it does not have to be empty.
If the cup seal goes bad, it cannot "push" enough pressure to actuate the brakes and you get a to the floor event, plus a brake light due to not enough pressure.
Re: Power Disc Brake Problems [Re: Andrewh] #135194
10/12/08 09:16 PM
10/12/08 09:16 PM
Lowell Mi
Lowell Mi
I think you may be on to something there Andrew. Front portion was full to point of spilling over. Is the solution to replace the complete master cylinder and reservoir? Thanks Greg
Re: Power Disc Brake Problems [Re: Rat_Exterminator] #135195
10/12/08 09:44 PM
10/12/08 09:44 PM
Andrewh Offline
Andrewh  Offline
yep, or rebuilt it if it is a show car or you need a particular partnumber.
Otherwise just swap it out.
Re: Power Disc Brake Problems [Re: Rat_Exterminator] #135196
10/14/08 11:31 PM
10/14/08 11:31 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Greg, I had this exact problem a few days ago.
Before you go pulling the M/C to swap it out, if you have power brakes, check the length of the rod going into the M/C from the booster and check the depth of the hole from the back surface of the M/C to the primary piston in the bore.
I checked mine after loosening the 4 nuts and found the pushrod was too long.
After sticking a small screw driver into the bore, then using my thumb to indicate the mounting surface of the M/C (a makeshift gauge)and comparing the length of the screwdriver blade to the length of the rod protruding from the booster, I eyeballed it and turned the rod clockwise about 1 1/4 turn, and got it to be equal in length to my gauge.
You can use a tire tread depth gauge to get better accuracy, or a small measuring tape or pocket ruler it you have one.
Everything is ALL good now. Chaz now brakes like it should, and that might be all you need to do.
Good luck!
Re: Power Disc Brake Problems [Re: MowP4rsn] #135197
10/15/08 07:26 AM
10/15/08 07:26 AM
sounds like you need a new master cylinder.
does it look like this:
if so i just got one at o'reillys for $22
http://www.cardone.com/English/club/members/customer/ecat_brands/imageinfo.asp?PARTNUM=10-1404#
