904 or 727 on an engine stand? #1350938
12/13/12 04:16 PM
12/13/12 04:16 PM
North Central Florida
E
eightlitermopar Offline OP
E
Has anyone done this for valvebody work? Any issues?
Right now I am working on a 904...
Thanks!
eightlitermopar
Mopar or no car
Re: 904 or 727 on an engine stand? [Re: eightlitermopar] #1350939
12/13/12 04:18 PM
12/13/12 04:18 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
piece of cake. Bolt it up just like you would a block, except with a nut on the other side..
Re: 904 or 727 on an engine stand? [Re: eightlitermopar] #1350940
12/13/12 09:01 PM
12/13/12 09:01 PM
Inver Grove Heights MN
74RR Offline
74RR  Offline
I mounted a 904 on a engine stand when I installed a manual valve body. Worked great. Would not have done it any other way.
Re: 904 or 727 on an engine stand? [Re: 74RR] #1350941
12/13/12 09:50 PM
12/13/12 09:50 PM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
Did a 727 on a stand. Great for valve body work but can't take front pump out with it mounted.
Re: 904 or 727 on an engine stand? [Re: GKMOPAR] #1350942
12/13/12 10:24 PM
12/13/12 10:24 PM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
I was able to get the front pump out of my 904 with it bolted to the engine stand.... Just need to position it properly.
Re: 904 or 727 on an engine stand? [Re: eightlitermopar] #1350943
12/13/12 10:24 PM
12/13/12 10:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I made this for my engine stand
then you can turn it up too
Re: 904 or 727 on an engine stand? [Re: Dodgem] #1350944
12/13/12 11:09 PM
12/13/12 11:09 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Been using this on a bench for years. Works great. Plywood, some 2x3's and angle iron.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 904 or 727 on an engine stand? [Re: Dads426] #1350945
12/14/12 12:35 AM
12/14/12 12:35 AM
E
E
Cool stuff guys, thanks!
My main concern was cracking the case or something like that.
I'll bolt mine up tomorrow and get to work while the snow comes in!
Thanks again!
eight
Mopar or no car
Re: 904 or 727 on an engine stand? [Re: eightlitermopar] #1350946
12/14/12 02:44 AM
12/14/12 02:44 AM
Friend of mine made this setup for me; lets you rotate the trans from vertical to horizontal, etc., and leaves the bellhousing area clear.
Re: 904 or 727 on an engine stand? #1350947
12/14/12 10:16 AM
12/14/12 10:16 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I went even cheaper. Because I don't build a trans very often, I just used my engine hoist and a strap. You can set the level wherever you want.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 904 or 727 on an engine stand? #1350948
12/14/12 02:46 PM
12/14/12 02:46 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
have you got a better pic of the other side?
Re: 904 or 727 on an engine stand? [Re: bonefish] #1350949
12/14/12 06:50 PM
12/14/12 06:50 PM
The trans case shown above is in my 59 Coronet now. Here's what my home-made trans stand looks like w/o a trans on it.
Re: 904 or 727 on an engine stand? #1350950
12/14/12 06:53 PM
12/14/12 06:53 PM
Another angle. The tubes are threaded so you can just bolt the case to the tubes.
Re: 904 or 727 on an engine stand? #1350951
12/14/12 07:13 PM
12/14/12 07:13 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thanks,and keep your eyes peeled for a 57-59 dodge 2 door.
