Page 2 of 3 1 2 3
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: BigMoneyLewis] #135087
12/26/08 10:10 PM
12/26/08 10:10 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
I used to own a '72 'Cuda 340 that was FE5 Red with V21 and colored grille .
Greg
Just curious if you know the VIN? I have the same car and it's from Maryland or the South originally - very few built like that!
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: 1972CudaV21] #135088
07/07/12 07:29 PM
07/07/12 07:29 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135089
10/10/12 07:26 AM
10/10/12 07:26 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
who bought this car.....
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135090
10/10/12 09:22 AM
10/10/12 09:22 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I dont usually like the colored grill but the TB3 blue looks good.
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135091
10/11/12 12:02 AM
10/11/12 12:02 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Thanks Larry, this raises another question for me now as I always assumed from the photos I have seen that the orange area in the argent grilles was black on the body color grilles. Does anyone have any info on this?
I guess the 73 had the color key grille as an option
http://www.allpar.com/model/cuda.html
I have a green grille I removed from a 1973 Cuda in 1980 or so, and the orange area is dark argent, not black.
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: 4406bbl] #135092
10/11/12 06:48 AM
10/11/12 06:48 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Sherwood green Metalic was one of the colors listed for the option on Cuda models in 72. Can you post pics of this?
Are you sure it was a 73? I'd like to see an option chart for 73
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135093
10/11/12 07:05 AM
10/11/12 07:05 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Did the '72 "colored grill" last the entire year? I have a 5/72 EV2 'Cuda should the grill be orange? It does have G36 & V6W but no V21.
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135094
10/11/12 07:07 AM
10/11/12 07:07 AM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
I just got this blue grille with a dark argent where the orange is on most.I have found no signs of a repaint?
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: moparclown] #135095
10/11/12 07:08 AM
10/11/12 07:08 AM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
second pic
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: 6bblgt] #135096
10/11/12 09:56 AM
10/11/12 09:56 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
My car was built 12/71 is FE5 and has the G36 and V21(seen above in this thread) and from what I've seen not all cars in the listed colors seem to have had the color keyed grille. It was theorized by one member that just as in the 71 Cuda production the supply may have had an effect on the what they actually assembled the cars with. I think that the option was seen in early built cars.
Checking over the option sheet the G36 and grille must be a seperate deal. I've personally only seen it on V21 cars and on one B5 blue car (online) that was repainted, not sure if it was added. I was basing my assumption that the G36 and color keyed grille were tied together some how, from what I had seen. I've only seen the painted grille on cars with painted mirrors and V21. (The orange car with the Hemi and shaker is/was also a V21 car).
The Cyber Cuda does not currently have a color keyed grille. Wonder what it's build date was, and if it ever had one?
I'd guess the built date and plant would coincide on cars with the painted grilles. I am going to start contacting the members I know of with these cars for build sheet and data tag info
Moparclown Thanks, if you can post extreme close ups of the paint , texture and termination point tape lines that would a huge help. So not texture found on the painted portion of the grille to indicate it had Argent sanded off?
6bblgt if you could do the same that would be great.
I imagine a few of these cars with this option would have had broken grilles replaced with Argetn units over the years and who could tell and how?
I spoke with a buddy and am planning to go look thru a factory manual tonight that MAY have some data on this option
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135097
01/16/13 11:04 AM
01/16/13 11:04 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Ok home sick, so I thought I'd update to this post again.
I've corresponded with some more owners of 72 Cuda's both V21 and G36
One owner of an EV2 Cuda with the G36 option (non V21) provided pics of his grille while it was still in original paint. So more proof that the loop was argent, not black as I had previously presumed from the appearance of the black and white press release photo's this car's scheduled production date July 10 of 1972.
My cars build date is actually 12/71 (I mistyped it in the original post and can't change it) and is a G36/V21 car. I know my car history since the prior owner was family. He informed me that the prior owner said that the grille was correct and should be body color (it had a color change at that time) I actually bought/delivered/refinished and helped install an argent grille back in the day. Reveiwing broadcast sheets I see something but will need a few more G36 cars sheets to compare.
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135098
01/16/13 12:03 PM
01/16/13 12:03 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Blaine Kelly's Cyber Cuda had body color mirror's but not a painted grille http://kelleyhome.homestead.com/cybercuda.html
The car is currently owned by Bob Malcom Dodge in Ohio http://www.bobmalcom.com
Bob's wife Sharron Malcom was nice enough to fax me a copy of the broadcast sheet. I can see that it is coded for V21 but G35 O/S Lh remote chrome mirror
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135099
01/16/13 03:16 PM
01/16/13 03:16 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
The ebay car did get sold, and I subsequently lost track of it.
If anyone knows of it, I'd like to get it touch with it's current owner.
The broadcast showed V21 but the data tag did not?? It also showed G36 on the tag/sheet, and had a color keyed grille
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #135100
03/10/13 07:16 PM
03/10/13 07:16 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Another 72 apparent G36 car from ebay (no data tag option codes provided)
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: 4406bbl] #1868165
07/11/15 11:23 AM
07/11/15 11:23 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Kick starting a classic thread, these photo's show the color of the painted area around the grille sections that was normally orange on argent grilles.
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #1873124
07/18/15 07:47 PM
07/18/15 07:47 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
An old ad, it can be found in the Oct 1971 Hot Rod (oh and FYI my broadcast sheets turned up up , owner #2's son came through)
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #1892861
08/16/15 10:44 AM
08/16/15 10:44 AM
Gillett, Pa
3404speed Offline
3404speed  Offline
Gillett, Pa
So as far as I can tell, the G36 option for color keyed mirrors plus the BS Cuda designation allowed for the colored keyed grill in certain colors. Orange Blue Red and Yellow being the most common. I have a late built 72 07/10/72 that is fender tagged G36 and has the color keyed mirrors and grille (pictured above in another post.) Have not pulled the broadcast sheet, but it is not a V21 car, nor does it have stripes or vinyl top.
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: 3404speed] #1892867
08/16/15 10:50 AM
08/16/15 10:50 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Exactly... and thanks John, it took me a few years but I'm learning. (check the date on the first post in this thread)
As the chart on page one details a Cuda (BS VIN) with G36, in any of the 6 specified colors should have come std with the color keyed grille.
I want to record as many as I can to see if they fall off at a certain date possibly due to a supply issue (as they say 71's did when a delivery truck rolled over)
I also actually found a relocated California 72 TB3 V21 here, it has aftermarket mirrors and argent grille but upon inspection appears to have had a minor front end collision (If I recall corrctly it had a factory replacement P/N stamped hood, I know the hood latch support was not painted) it's a G36 car built 8-71 so I'd say it had the color keyed grille.
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: UCUDANT] #1893733
08/17/15 06:18 PM
08/17/15 06:18 PM
Southeast Wisconsin
Sunroof_Cuda Offline
Southeast Wisconsin
I have a 1972 Cuda with a July 14 build date and V21, GF7 paint. When I got the car, it still was largely in original paint. The grille as entirely green, no argent border. It has one chrome remote mirror, side stripes, black vinyl top.
Re: 1972 Cuda V21 hood & color keyed grille options ? [Re: Sunroof_Cuda] #1897975
08/23/15 10:48 PM
08/23/15 10:48 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Sunroof I was unaware you had two 1972 V21's. I'd love to document this car and any original condition photo's you have of it. Here is a pic, it's a still from a preproduction video it was apparently a factory deal made from photoshoot still's and voiced over, that I've just aquired
Page 2 of 3 1 2 3
