rallley dash cluster problem
#134796
10/10/08 04:30 PM
10/10/08 04:30 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i think i have just did something bad, i have 1968 ralley cluster, i was trying to install into my car and i accidently bumped one of the 5brass tubes coming out of the back of the cluster, it bent and when i tried to straighten it, it tore almost into, what are the tubes for? i am guessing the oil pressure gauge, how to fix this or is this cluster toast? thanks
Re: rallley dash cluster problem
[Re: 1_WILD_RT]
#134805
10/10/08 09:24 PM
10/10/08 09:24 PM
cornet684me
Brandon, Ms
well i got a funny story for you, i have bought all the ralley dash pieces, cluster, bezel, dash pads , radio bezel, glove box , upper glove box bezel, i have not taking my dash apart yet, i am still needing the ralley dash frame, someone had sent me a non rally dash frame and i was trying to make it work, i don't think this will work, well anyway, i have not taken my dash apart yet, in fear that i do not have all the pieces i need to get it to work, so i was trying to put the ralley dash together before i take out my dash
[Re: 1_WILD_RT]
#134810
10/10/08 09:34 PM
10/10/08 09:34 PM
cornet684me
Brandon, Ms
it sure wld help if i could get a diagram or something, this is my first mopar and i am doing this blind, trial and error, and it is turning out that i have more error then trial there have been alot of good mopar guys that have talked me thru the whole project, i am down to the paint and the interior, i was really wanting to add the ralley dash, but i maybe opening a can of worms
[Re: 1_WILD_RT]
#134812
10/10/08 10:41 PM
10/10/08 10:41 PM
cornet684me
Brandon, Ms
okay, i just found a old standard cluster i have, the connector on it is round, it only has about 9wires in a circle, i have my ralley cluster and it has the 5brass flat connector, and then about 20 different wires goint to all the switches, so now i have figure out i need a ralley dash wiring harness to make this work, do i just have to pull out the standard wiring harness and re-install the ralley wiring harness?
