Re: went edel victor aluminum head finaly!
[Re: Clanton]
#1347070
12/08/12 01:43 PM
12/08/12 01:43 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
You could also have them hand ported instead of a one size fits all cnc port job. I know cnc is the trend nowadays but just something to think about...!
Brian Hafliger
[Re: Brian Hafliger]
#1347071
12/08/12 01:59 PM
12/08/12 01:59 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Thanks!I was thinking more on the hand porting and that is from a cost factor for now.
[Re: Clanton]
#1347072
12/08/12 07:51 PM
12/08/12 07:51 PM
Clanton
northern,Ohio,USA
I measured the bolt hole depth and I will be able to use the studs I have in there.SWEET! edelbrock outside .930 inside 1.030 middle 3.370
factory iron +/- .005 1.000 .975 3.040
[Re: Clanton]
#1347075
12/12/12 12:42 AM
12/12/12 12:42 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
Are those CFM measurements at .100 to .800 valve lift?
[Re: Cab_Burge]
#1347078
12/12/12 01:14 AM
12/12/12 01:14 AM
Clanton
northern,Ohio,USA
Yes
Well,Why do you ask ?LOL
[Re: Clanton]
#1347079
12/12/12 04:25 AM
12/12/12 04:25 AM
Cab_Burge
I was curious as to which numbers meant which numbers I'm assuming the second row is thw adapter use to flow at those numbers and the second line is the results in CFM, yes? Also what are the top numbers ?
[Re: tboomer]
#1347084
12/12/12 11:54 AM
12/12/12 11:54 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
I am watching this one! Are those the standard 77929 Victors out of the box? Mine started out as the standard port but were ported to MW size..I am thinking I went overkill on this!!
Ted, this word should not even be in your vocabulary
Go have some fun
Russ
[Re: Clanton]
#1347087
12/12/12 12:24 PM
12/12/12 12:24 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
Clanton, So you are Boosting the motor? Try to raise the mid to upper lifts, the intake needs volume more than raw CFM and great exhaust efficiency is also important; that's what makes the Indy-1 with it's big Intake port and excellent raised exhaust a real natural for blower apps. You want to improve the exhaust to intake bias % since getting air IN is not an issue with boost, and for the powerband you're looking at...you don't want or need a ton of RPM since your torque band is going to be EPIC and roots blower efficency drops (heat) and tends to act as a big brake on the crank past its designed flow rate. Good heads and a relatively slow blower ratio really works great....if you get the cam and timing right it's almost unbeatable and VERY RELIABLE. I have the Chaoman stage VI's and the most impressive/important numbers are the mid lifts. Basically if you get your .400-.500 OOTB lift numbers to where your OOTB .500-.600 numbers are now and IMO you're all set. beyond that with the blower you just let the peak fall where they may beyond that. Cam selection will be critical, how big is the blower and what CID and static CR are you at. JE makes a nice blower/nitrous dish design. Run as long a rod as possible
