Re: Stock oil pan. Where to find a decent pan? [Re: cudabitten] #1346321
12/08/12 09:18 PM
12/08/12 09:18 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Well I said I would tell how this fits, so here goes.
It went on real good no problems. Seems like all gaps are equal around the perimeter, so hopefully it seals well too.
Pics are without gasket.
Re: Stock oil pan. Where to find a decent pan? [Re: cudabitten] #1346322
12/08/12 09:53 PM
12/08/12 09:53 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
The milodon stock replacement pan is a good quality piece. It even has an extra baffle. Works great with a stock pickup as well.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346323
12/09/12 09:35 AM
12/09/12 09:35 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
For a big block, I like the Hemi pans from Mancini. Extra quart of capacity, and no ground clearance penalty. You will need one of their pick-ups though. Stock pick-up will hit the baffle. I suppose you could clearance the baffle and make it work.
Note that I have had quality issues with a couple of these. One with a loose baffle, another with a cross threaded drain plug. Both were replaced before installation.
On a small block I like the Kevko pans. Well baffled, and have a extra capacity without sacrificing ground clearance. A Kevko pick-up is required.
Summit stock replacement small block pans are not baffled (even though the description on the website says they are... neither is the stock one). With the rather puny stock capacity, that makes me nervous. Milodon stock replacement pan has an added baffle, but still has puny capacity, and they are a bit pricy.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Stock oil pan. Where to find a decent pan? [Re: cudabitten] #1346324
12/09/12 01:29 PM
12/09/12 01:29 PM
Inver Grove Heights MN
74RR Offline
74RR  Offline
Thanks for the update!
