Hughes Camshaft snout extension #1345689
12/04/12 01:55 AM
12/04/12 01:55 AM
Sturgis S.D.
tripleblackcuda Offline OP
Sturgis S.D.
Has anybody used or installed the camshaft snout extension kit that Hughes engines sells? I am trying to put one on my 1991 360 motor and something just doesn't look right. Don't know if you need to remove the key from the cam or not....
Re: Hughes Camshaft snout extension [Re: tripleblackcuda] #1345690
12/05/12 12:54 AM
12/05/12 12:54 AM
Sturgis S.D.
Sturgis S.D.
I looked at it and put it together tonite the way its says to and it seems like there is nothing in the way of a key-way to hold the eccentric in place. What am I doing wrong here?
Re: Hughes Camshaft snout extension [Re: tripleblackcuda] #1345691
12/05/12 01:40 AM
12/05/12 01:40 AM
I've never used one but can you post a pic?
Re: Hughes Camshaft snout extension [Re: RapidRobert] #1345692
12/05/12 02:08 AM
12/05/12 02:08 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have used a few & own a couple
I use a key with a tang on the end
Re: Hughes Camshaft snout extension [Re: tripleblackcuda] #1345693
12/05/12 08:06 PM
12/05/12 08:06 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I have one in my Magnum based stroker. I don't remember any issues installing per Hughes instructions. It has worked for a few years now. As stated previously can you post a pic??
