Re: Barn Find...Well Craigslist 69 GTS Convert
[Re: RUNCHARGER]
#1344402
12/01/12 01:35 AM
12/01/12 01:35 AM
Posts: 1,300 Washington
19cuda73
Washington
Nice find!!! keep us posted and pictures coming
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: 440PURSUIT]
#1344406
12/01/12 11:34 AM
12/01/12 11:34 AM
moparpollack
Lil Herman
Lil Herman
85086
Yes it was. . Got a few extras too.
Thief! ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: And It RUNS! Pretty good
[Re: 440PURSUIT]
#1344409
12/01/12 02:28 PM
12/01/12 02:28 PM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
You guessed right, Jeff! ![](/ubbthreads/images/graemlins/smile.gif) Full blown MADD still living here. Good seeing you at St Peters Breakfast with Santa. Call me when youre done.
[Re: 440PURSUIT]
#1344410
12/01/12 05:10 PM
12/01/12 05:10 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Jealous.. Cant believe people still find deals like this!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: 440PURSUIT]
#1344411
12/01/12 05:26 PM
12/01/12 05:26 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Motor was tight and didnt have spark. Drained oil and had lumps coming out. Put a couple quarts of Kerosene in Oil pan overnight. Drained today and added new oil and flush. Also let cylinders soak in Marvels over night with plugs out.
Bad coil and condenser changed. Changed Plugs, too-had AC XLS-44 from store closeout.
Turkey baster always handy after Thanksgiving. Primed carb, but no pump shot. Down the hatch and fired up with a twist of distributor it was singing and pumped up lifters. Ran for about 10 mins w 40psi @ 2000 rpm.
We be pressure washing the crud now. Rust and sludge are flying! Will change oil and filter again.
Hey Chris you can always try the Rick Hunter method of engine clean out...start it up, bring the rpms up and turn the garden hose down the carb.... That'll make her nice and clean.
Re: Owner Info
[Re: 440PURSUIT]
#1344414
12/01/12 09:22 PM
12/01/12 09:22 PM
Posts: 6,301 colorado
a12superbee
colorado
Too bad about the trash man picking up the motors and such, maybe you can still track them down.
I can't afford this.
mark
