Re: cleaining the inside of a 8.75 housing
[Re: BigDaddy440]
#1343473
12/03/12 02:07 AM
12/03/12 02:07 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I found a local blasting facility that is sand blasting the inside for $40. Heck of a deal if you ask me!!!
I was told to blast with caution, and not the inside. While blasting will clean the inside there will be little places where media (sand etc) sticks to the grease and you'll have a hard time seeing it or getting it out. Then it was clause issues with your diff down the road.
A solvent tank / Acid Dip process is a better route I think, as the grease is removed and the metal is clean.
If you have the outside blasted only seal up the housing really really well to prevent media from getting inside.
-dan
There was no oil or grease on the inside. It was dry as a bone and rusty and scaly. The axle ends really weren't that bad. The axles came out pretty easily as did the axle seals. I'll hit the axle seal and bearing ends with a cylinder hone just to clean them up a bit. It'll be good to go.
[Re: Cab_Burge]
#1343476
12/03/12 10:19 AM
12/03/12 10:19 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Run this though the rear end housing with a pool pump for a few hours... Rust remover
I agree that this and other similar products like Evaporust and Unrust will do a great job, however if he can get it done at a machine shop for $40.00 they are typically going to cost more to get the job done based on the size of the rear end housing and the amount of those products needed to do the job, hence my suggestion to use the home brewed vinigar mix instead. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Stanton]
#1343477
12/03/12 01:28 PM
12/03/12 01:28 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
I would think finding another housing would be easier and cheaper !!!
We found the Powerball winner!!!!! Priced one for an A lately? :-)
[Re: pishta]
#1343478
12/03/12 02:59 PM
12/03/12 02:59 PM
mopowers
Sac, CA
It's interesting how people like to spend other's money. I'll happily take donations for a new one. But that ain't happening, so the next best is refurbishing this one. Once it's together, there'll be plenty of year of service left in this old housing.
