Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed
[Re: EL5 71]
#1342556
07/15/13 05:11 PM
07/15/13 05:11 PM
Posts: 562 New York
EL5 71
New York
Here's a pic of it installed on your old car Troy. I know the fella Pete who owns her in New York now. There's a little tiny hole on the rad. support on Chargers for the upper attatching screw on the bottle bracket. It's pretty tough to even notice it there because that area is usually blacked out.
[Re: EL5 71]
#1342559
07/15/13 11:35 PM
07/15/13 11:35 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Well, shiver me timbers !!!! I do learn something new every day and I need to go back to my stash, I think the bottle I have has the bracket !!!!
and Boy, you about tore my heart out with that picture !!!! I miss that car!!! I take it he still has it then....... I hope so...... I need to get in contact with him for ole-time sake......
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: EL5 71]
#1342560
07/16/13 10:42 AM
07/16/13 10:42 AM
Posts: 16 Minnesota
billrabe
Minnesota
Here's the Flasher. Same for Charger and Fury.
What is the flash rate for this flasher? It does not appear to be commonly available. It appears to be a two prong flasher and I would expect it is 12 volts and flashes only 1-2 times per second. From what I could tell from searching online, they were made by Tungsol in Newark, NJ or Ideal corporation of Brooklyn, NY. Also, the reservoir for the Fury appears to be different than the one for the Charger.
