71 CUDA TORSION BARS #1341808
11/26/12 07:17 PM
11/26/12 07:17 PM
cudaman440_1 Offline OP
HEY YALL, Has anyone done away with torsion bars and added coilovers
useing the stock k-menber and lower control arm
Johnny
Re: 71 CUDA TORSION BARS [Re: cudaman440_1] #1341809
11/26/12 11:21 PM
11/26/12 11:21 PM
IMGTX Offline
IMGTX  Offline
I do not think it would be possible using stock parts alone.
By itself I do not believe the LCA would do a good job of staying in place. The Tbar will keep the LCA from moving backwards so unless you created a different method of restraining it I do not believe it will work.
Also the Stock Shock Mounts are not beefy enough to support the car's weight. Over time the fender apron will collapse.
To do this you will need a reinforced mounting point for the coilover shocks.
My
Re: 71 CUDA TORSION BARS [Re: cudaman440_1] #1341810
11/27/12 02:21 AM
11/27/12 02:21 AM
AndyF Online content
AndyF  Online Content
Yes. The Pro Stock guys were doing that about 40 years ago.
Re: 71 CUDA TORSION BARS [Re: AndyF] #1341811
11/27/12 02:32 AM
11/27/12 02:32 AM
I think it can be done
Re: 71 CUDA TORSION BARS [Re: AndyF] #1341812
11/27/12 02:35 AM
11/27/12 02:35 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Let me guess, you are trying to gain better clearance for the exhaust system, right?
This is a common question here, and it is a heated topic. Common wisdom is that, as stated, the cars were designed around the torsion bars and the shock mounts were never designed to carry the loads of a spring. The loads imparted by a shock absorber are far less than that of a spring. There are ways to reinforce the aprons through gussets and a 3 point "Monte-carlo" bar/gusset under hood/over the engine. If your goal is to cut weight, this is a bad idea. The additional gussets and bracing for strength are much more than the factory T bar setup.
The easy way to gain exhaust clearance is to buy better headers. It sucks though that they cost so much.
Re: 71 CUDA TORSION BARS [Re: Kern Dog] #1341813
11/27/12 04:04 AM
11/27/12 04:04 AM
I got the good headers, I was just kicking it around and was i thinking of a rack and pinion something i could fab myself.
Re: 71 CUDA TORSION BARS [Re: cudaman440_1] #1341814
11/28/12 01:18 AM
11/28/12 01:18 AM
I need more input please
Re: 71 CUDA TORSION BARS [Re: cudaman440_1] #1341815
11/28/12 02:20 PM
11/28/12 02:20 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
There is/was a company near cleveland Oh..unisteer I think.
they had a bolt in deal that i looked at a few years ago when i was thinking about turbo charging a 5.7 hemi in my cuda. Looked quality when i toured the plant.
V10
Re: 71 CUDA TORSION BARS [Re: V10nacuda] #1341816
12/21/12 05:28 AM
12/21/12 05:28 AM
SE PA
Yellow Fever Offline
SE PA
