When is a Pro gearset required? #1341591
11/26/12 10:04 AM
11/26/12 10:04 AM
tboomer Online work OP
tboomer  Online Work OP
Like the title says..When do you need a Pro gear ring and pinion set? Discuss!
Re: When is a Pro gearset required? [Re: tboomer] #1341592
11/26/12 10:12 AM
11/26/12 10:12 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
when you make power/torque that can shatter teeth on ring/pinion...
thats why I am using a pro-gear and a spool on the street in my 9" that will be installed in my 63 Dodge...with about 700hp and over 650lbs ft of torque, I would be breaking street gears and eating differentials..
hypothetically speaking of course....
Re: When is a Pro gearset required? [Re: tboomer] #1341593
11/26/12 10:15 AM
11/26/12 10:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never found the need for a pro gear... light
cars are EASY on parts
Re: When is a Pro gearset required? [Re: MR_P_BODY] #1341594
11/26/12 10:18 AM
11/26/12 10:18 AM
Thanks,Jeff and Raff! My car isn't that light at 3400#...And I launch off the tranny brake...
Re: When is a Pro gearset required? [Re: MR_P_BODY] #1341595
11/26/12 10:24 AM
11/26/12 10:24 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
What Mr. P-Body said.
It has more to do with impact than Torque/HP. A heavy stick car, or leaf spring car that bucks around, hook-spin-hook, those are the situations that are more likely to break a street gear.
My 70 Challenger has a back braced 8 3/4, and in 1100 passes, I've broke one ring gear, and that was on a marginal track with a heavy dose of Nitrous.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: When is a Pro gearset required? [Re: MoparBilly] #1341596
11/26/12 11:00 AM
11/26/12 11:00 AM
Billy...My beater has ladder bars..
Re: When is a Pro gearset required? [Re: tboomer] #1341597
11/26/12 02:19 PM
11/26/12 02:19 PM
iowa
bad1970dust Offline
"Hollywood"
bad1970dust  Offline
"Hollywood"
iowa
teddy my car ain't as fast as yours lmao.. I dont run pro gears
Re: When is a Pro gearset required? [Re: bad1970dust] #1341598
11/26/12 02:50 PM
11/26/12 02:50 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
At 2850 lbs. and 600 HP, a street gear in my 8-3/4 would last 100 runs, then inspection would show a number of chipped ring gear teeth. Pro gear has been in it since 1996.
Re: When is a Pro gearset required? [Re: tboomer] #1341599
11/27/12 02:27 AM
11/27/12 02:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm still using street gears, but I use the Red-Line Shock-Proof gear oil.
http://www.redlineoil.com/Products.aspx?pcid=8
Re: When is a Pro gearset required? [Re: smokinwoody] #1341600
11/27/12 03:51 AM
11/27/12 03:51 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
With a 9, you should be breaking parts at that low of power! Jana 76 all the way! 10.5" ring gear in a 60 housing.
Re: When is a Pro gearset required? [Re: bad1970dust] #1341601
11/27/12 08:20 AM
11/27/12 08:20 AM
Right,Jimmy.. After all...Yours has only ran 7.79...Step away from the Crown Royal!!
Re: When is a Pro gearset required? [Re: astjp2] #1341602
11/27/12 09:51 AM
11/27/12 09:51 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
are you trying to say that I shouldn't be breaking gears at my power setting??....
I have Dana 60 in my Camaro with street gears and a differential...its a 4spd and I have launched at 6700 rpm without a whimper...thats why I changed out the 12 bolt that was in it...
I bought the 9" from a guy that was getting out of racing...all new stuff...the gears are A/FX pro gears and are setup to allow gear oil to climb more effectively over the rear of the ring gear...in order to cool it better on the street....I have talked to many guys that set up gears and had asked if a diff and street gears would be a better way to go given my setup....they all agreed ...Pro-Gears and a spool....
hope any of this helps you Ted...
Re: When is a Pro gearset required? [Re: tboomer] #1341603
11/27/12 10:21 AM
11/27/12 10:21 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
My car made 1300 hp and 1000 ft lbs of torque
Street Gear was fine
Jason Ruckert of VP made WAY more power than me and he ran a street gear with no problems
Re: When is a Pro gearset required? [Re: joshking440] #1341604
11/27/12 10:56 AM
11/27/12 10:56 AM
Yes...But were you guys launching off of a tranny brake?
Re: When is a Pro gearset required? [Re: tboomer] #1341605
11/27/12 11:14 AM
11/27/12 11:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have been from day 1
Re: When is a Pro gearset required? [Re: MR_P_BODY] #1341606
11/27/12 11:16 AM
11/27/12 11:16 AM
Raff...My car is 3400#...Won't this come into play? I can only afford to do this once!
Re: When is a Pro gearset required? [Re: tboomer] #1341607
11/27/12 11:48 AM
11/27/12 11:48 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
Ted... my car is 3350#, runs high 9's and using a trans brake. I can get about a year out of a set of street gears (Dana 60) before the pinion teeth start to fail. If I foot brake, I can nearly tripple that. For me, a pro set of gears are the way to go. When the rearend wine get noticeably louder, it's telling me to change them out. For me, its easier and quicker to change out gears before they fail completely then to tear down the trans and inspect the sprag. It's your choice, just offering up some personal experience. Good Luck!
Re: When is a Pro gearset required? [Re: Gearhead383] #1341608
11/27/12 11:55 AM
11/27/12 11:55 AM
Thank you! If I do everything to this junker,it is quite possible that it may hit the high 9.xx mark. Only time and cash flow will determine that.
Re: When is a Pro gearset required? [Re: tboomer] #1341609
11/27/12 11:55 AM
11/27/12 11:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Weight kills.... even if you go with the pro gear
it will only last so long, they're softer to take
the shock but they start to roll the teeth after time
Re: When is a Pro gearset required? [Re: Gearhead383] #1341610
11/27/12 12:00 PM
11/27/12 12:00 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
TBOOMER- Your car is no light weight...
Your new heads have received some "Radar Love"
Its gonna make a lot more power......
Things can get ugly with a drivetrain failure and a torqueflite....(Dont ask me how I know)
I think I could sleep better at night with a Pro Gear in that thing......
Curator at Adams County Speed Shop
