Page 2 of 11 1 2 3 4 10 11
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341440
11/26/12 12:27 AM
11/26/12 12:27 AM
Oreland Pa
clonedshaker+6 Offline OP
Oreland Pa
primer
71 challenger 440 sixpack shaker *CLONE* (71challenger 440+6 shaker clone FAST/my HS grad present)
03 mustang Mach 1 (daily driver)
11.35 @ 121.5 4 SPEED on F60-15s w/ 6/32 tread
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341441
11/26/12 12:28 AM
11/26/12 12:28 AM
Oreland Pa
Oreland Pa
good picture
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341442
11/26/12 12:29 AM
11/26/12 12:29 AM
Oreland Pa
Oreland Pa
thats all for now
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341443
11/26/12 10:22 AM
11/26/12 10:22 AM
midwest
68427vette Offline
68427vette  Offline
midwest
nice , i'll be watching, color????
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: 68427vette] #1341444
11/26/12 10:38 PM
11/26/12 10:38 PM
Oreland Pa
Oreland Pa
what i had in mind for a while is B7 blue, black interior, black vynal top, black R/T stripe, B7 steel wheels w/ dog dish, power windows, rallye gauges, floor shift auto, and shaker is what i plan on/hope to have when its done
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341445
11/27/12 10:54 AM
11/27/12 10:54 AM
SE Pa.
LimeliteAero Offline
SE Pa.
SWEET!
I cant wait to see it. with your support group you may be finished before I finish my project.
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: LimeliteAero] #1341446
11/27/12 06:27 PM
11/27/12 06:27 PM
Millersville, PA
HemiChallenger Offline
Millersville, PA
Nice project you got there. Get that thing together and well criuse. were not to far from each other. Let me know if you need any parts, i gotta bunch of extra stuff ...
Steve
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: HemiChallenger] #1341447
11/27/12 10:49 PM
11/27/12 10:49 PM
Oreland Pa
Oreland Pa
thanks guys and steve i will deffinatly let you know if i need any parts, i most likely will and meeting up and cruizing sounds like a great idea
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341448
12/10/12 11:01 PM
12/10/12 11:01 PM
Oreland Pa
Oreland Pa
over the past week and weekend i got some more work done getting me a few steps closer to body work
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341449
12/10/12 11:03 PM
12/10/12 11:03 PM
Oreland Pa
Oreland Pa
repaired the small swiss cheese rust holes in the floor
thanks to who ever pulled the carpet out a long time ago it saved me tons of work replacing a floor pan
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341450
12/10/12 11:06 PM
12/10/12 11:06 PM
Oreland Pa
Oreland Pa
repaired the blistered frame rail
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341451
12/10/12 11:07 PM
12/10/12 11:07 PM
Oreland Pa
Oreland Pa
more frame rail repairs
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341452
12/10/12 11:41 PM
12/10/12 11:41 PM
Oreland Pa
Oreland Pa
need some advice from fellow members preferrably someone who has replaced a fire wall. as you can see in some of the pictures i posted my cowl and the firewall are fairly rotted so i plan on replacing the fire wall and upper cowl with the AMD parts but i want to do it with taking as little as possible off the car
my question for everyone is how should i go about bracing the car and if i should make a jig for the whole car to sit on before i start taking it apart and what i should do to make sure my car is straight when its all done, im not exactly sure where to start so any input would be greatly appreciated and i have time before i start the firewall, i have to finish the trunk area first because its already apart, so any thing you have that mite help me please give me your thoughts (its my first restoration trying to get as much help as i can)
thanks
Bryan
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341453
12/11/12 11:38 AM
12/11/12 11:38 AM
midwest
68427vette Offline
68427vette  Offline
midwest
here's some motivation from Alan's site!! a real 440/6 71 gutted
http://www.alangallantautomotiverestoration.com/1971-440-6-Challenger.html
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: 68427vette] #1341454
01/06/13 01:37 PM
01/06/13 01:37 PM
Chandler AZ USA
AZMoparboy Offline
AZMoparboy  Offline
Chandler AZ USA
Hi Bryan,
My Challenger looked a lot like yours in the firewall area. I changed mine out as you are thinking of doing.
I first studied lots of threads on here to figure out just what needed to be reinforced on the body of the car. I then went and bought steel to frame up the front of the car. I only have one picture of my car with the framing under the front of the car and hope this helps out. The rest of the car was all together. These cars are very rigid and lite, taking out one piece of the car and having it supported will keep every thing in place.
There is a thread here on moparts.com, in the member projects & survivor pictures called, "Project Rust Bucket: 1971 Challenger R/T". This thread has lots of pictures and you can see many ways to rig up the body of your car to hold it in place to change out your firewall.
These cars are not perfect from the factory. Yes they had tooling to hold the pieces together as it was welded together, but as you can read from anyone that has restored any of the old chrysler cars, no, one car is just like the other.
Just one more thing that I found to be just a little hard to work with was that I bought the cowl and firewall as one unit. I don't know how perfectly square these two items are from the vendor, but it was difficult. With the two pieces welded together it is a very rigid structure and I had to work hard to get the unit installed.
To all that read this, I am in no way a pro at this restoration stuff. This is just the way I did it and in no way implying that this is the only way or may not even be the way to do it at all. I don't want to come off like I know anything, I'm self tought.
Good luck, I will attach a pic.
Steve
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: AZMoparboy] #1341455
01/06/13 03:04 PM
01/06/13 03:04 PM
Chandler AZ USA
AZMoparboy Offline
AZMoparboy  Offline
Chandler AZ USA
Here is one of the firewall installed
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: AZMoparboy] #1341456
01/06/13 10:42 PM
01/06/13 10:42 PM
Oreland Pa
Oreland Pa
thanks alot for your input, im no expert either this is my first restoration. im 18 but have a number of people with experiance willing to help me so im learning as i do it and knowing its been done before id like to get as much input as possible to try and make better decisions when i go to fix my fire wall,
also i havent updated recently, been busy with the holidays and all that good stuff but have been working on it and will post new pictures hopefully this week ,Bryan
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341457
01/06/13 11:00 PM
01/06/13 11:00 PM
Oreland Pa
Oreland Pa
and theres a change in plans with the finished project, ive been looking at different cars on the internet and toying around with different combos in my head, so my plan for the car is
B7 blue
black vynal top
black interior
black R/T stripe
power windows
rallye guages
15x7 black steel wheels with dog dish caps
440 sixpack 4 speed w/ console
shaker hood
its pictured in my head and the only thing i would want different is a Hemi in place of the 440+6 but lets face it im 18 i cant afford no Hemi
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341458
01/08/13 11:41 PM
01/08/13 11:41 PM
Oreland Pa
Oreland Pa
setting the trunk floor
Re: 71challenger 440+6 shaker clone FAST/my HS grad present [Re: clonedshaker+6] #1341459
01/08/13 11:46 PM
01/08/13 11:46 PM
Oreland Pa
Oreland Pa
under side, original tank straps screwed in to make sure the fit is good on the new floor
