Re: 03' Dodge Stratus Build video [Re: Forest] #1340966
11/26/12 12:10 AM
11/26/12 12:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
WAY cool and a beautifull ride. I would assume you would have plans for an engine swap down the road since it`s certed for the 6`s..............
Re: 03' Dodge Stratus Build video [Re: Thumperdart] #1340967
11/26/12 12:18 AM
11/26/12 12:18 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Yea for sure, I want to build a 572 for it. Plan to run the div. 6 races this year and see what happens from there.
Re: 03' Dodge Stratus Build video [Re: Forest] #1340968
11/26/12 12:32 AM
11/26/12 12:32 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Very nice build and great job on the video. Thanks for sharing your build with us. What wheelbase did you end up with?
To clarify my last post wheelbase ended up at 105"
Thanks for the info. My mind keeps trying to talk my body into doing a rebody on my Daytona. Pretty sure it is only 97 or 98 inch wheelbase. My chassis is certified to 7.50 and is mild steel. It is a very hard car to bracket race or Top Sportsman because of visibility.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 03' Dodge Stratus Build video [Re: Forest] #1340969
11/26/12 12:33 AM
11/26/12 12:33 AM
Did you do all the carbon fiber work like the tubs yourself?
Simply awesome!
I can't fathom putting together a chassis like that.
The fact that it ran straight as a string down the dragstrip was pretty amazing too!
Re: 03' Dodge Stratus Build video [Re: Forest] #1340970
11/26/12 12:58 AM
11/26/12 12:58 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You`ve definately got the platform for it...........
Re: 03' Dodge Stratus Build video #1340971
11/26/12 01:28 AM
11/26/12 01:28 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Simply awesome!
Yes I did all the carbon fiber work too. What a scary day that was cutting the tubs off the template i had been working on!
I nicknamed my wife cranky because she runs the crank on the bead roller as I feed in the material; we have become a pretty good team when it comes to that!
Yea I was pretty stoked just to get past the first 6 licensing passes without any issues, but to turnaround and put 4 more 1/8 mile passes and 6 1/4 mile passes on it and not do anything besides adjust tire pressures was quite nice!
Re: 03' Dodge Stratus Build video [Re: Forest] #1340972
11/26/12 09:44 PM
11/26/12 09:44 PM
montana
BANDIT Offline
BANDIT  Offline
montana
What did it end up weighing with the smallblock in it? Where did you add the 2 inches in wheelbase? Again, awesome work, Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: 03' Dodge Stratus Build video [Re: BANDIT] #1340973
11/26/12 10:04 PM
11/26/12 10:04 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
The front tire is just moved forward 2" from the center of the opening in the fender...
Re: 03' Dodge Stratus Build video [Re: Forest] #1340974
11/27/12 02:30 AM
11/27/12 02:30 AM
WA
JD Dart Offline
JD Dart  Offline
WA
What class are you going to run in Div 6 look forward to seeing your car there. And what a nice car and great work you did on it.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: 03' Dodge Stratus Build video [Re: JD Dart] #1340975
11/27/12 11:05 AM
11/27/12 11:05 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Super Pro with the idea to try Super Gas in the years to come...
