Re: Project angry bird...68 roadrunner
[Re: pnypwr]
#1339759
11/26/12 01:14 AM
11/26/12 01:14 AM
Posts: 4,872 connecticut
pnypwr
connecticut
i need to change out the lower tie bar, i have a good one from another donor, and use my orig upper tie bar so my so number matches the trunk lip, even tho that will have to be grafted into whatever i use in the back whether its or steel or amd. I have found out its alot harder to find the spot welds on rusty metal...the air chisel has come in handy too! all for now, maybe some more tomorrow evening.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: basketcase]
#1339761
12/02/12 01:08 AM
12/02/12 01:08 AM
pnypwr
connecticut
started dissecting the orig front clip to keep whatevers saveable off of it, now I get a good view of how bad the rail really was
[Re: pnypwr]
#1339762
12/02/12 01:09 AM
12/02/12 01:09 AM
pnypwr
connecticut
another
[Re: pnypwr]
#1339763
12/02/12 01:11 AM
12/02/12 01:11 AM
pnypwr
connecticut
got the weld areas ground and primered with weld thru primer and the front section back together with the car
[Re: pnypwr]
#1339764
12/02/12 01:12 AM
12/02/12 01:12 AM
pnypwr
connecticut
all my measurements are within 1/16 of an inch, factory alignment holes line up nice, all clamped up and strapped up ready to start welding...
[Re: pnypwr]
#1339767
12/02/12 12:51 PM
12/02/12 12:51 PM
Holy Ding-Dang You have a pretty big project going there and a big kudo for taking it on and that much tougher doing it in cramped 1/4s. Keep the pics coming, looking good so far.
[Re: ]
#1339768
12/16/12 12:09 AM
12/16/12 12:09 AM
pnypwr
connecticut
actually got to the shop for an hour or two...no fun in the cold, but I couldnt let it warm up as I didnt know i was going to be able to get out there...but once the kids were asleep...I took the opportunity. I finished welding up the inner fenders and got it back on its wheels, then popped off the cowl...drilled the welds along the firewall and the air chisel took care of the rest...which wasnt much
[Re: pnypwr]
#1339770
12/16/12 12:12 AM
12/16/12 12:12 AM
pnypwr
connecticut
the bottom of the orig cowl cap
[Re: pnypwr]
#1339771
12/16/12 12:14 AM
12/16/12 12:14 AM
pnypwr
connecticut
the new cowl, havnt decided if im going to separate it yet or just drill thru where it attaches to the car and keep it sealed...
[Re: pnypwr]
#1339772
12/16/12 12:15 AM
12/16/12 12:15 AM
pnypwr
connecticut
I found this in the heater duct when i pulled the dash...was kinda the high point of actually owning this car...
[Re: RodStRace]
#1339775
12/18/12 12:57 AM
12/18/12 12:57 AM
pnypwr
connecticut
thats the twin to mine minus the post...I like the ice blue, thats kinda the reason I bought the car. Ill prob go get a pint of single stage for under the cowl, I plan to paint it up, im thinking ill use the cowl I already have drilled apart, just to save the hours of drilling...
[Re: RoadRunnerLuva]
#1339778
12/24/12 08:33 PM
12/24/12 08:33 PM
pnypwr
connecticut
more progress today...cowl went bye bye
