Re: 360 testing begins,....
[Re: Dunnuck Racing]
#1338699
01/16/13 05:05 PM
01/16/13 05:05 PM
Posts: 9,866 Weddington, N.C.
Streetwize
Weddington, N.C.
Keith, EXACTLY how much oil are you putting in the motor? I run a stock truck pan on my 414 with exactly 5 1/2 quarts w/filter and it clears the rods/crank. I would actually prefer to modify this pan to be deeper before the sump with just a screen/baffle, very simple to fab but I can't find anyone local I trust to do it for me, probably wind up doing the Milodon. I have no cross-member below the block so it's wide open. The way the motor is set inthe Rocky my center link actually passes across the gap between the front of the block/pan and the harmonic balancer I ALWAYS prefer a rear sump pan for drag racing (so long as the chassis/steering linkage will accomodate one, no matter how good or deep the front sump design may be.
[Re: ademon]
#1338702
01/17/13 04:00 AM
01/17/13 04:00 AM
Posts: 168 Washington State, USA
Winchester 73
i would love to see what happens with the pint over but with a windage tray added.
i think its kind of a moot point considering data from a stationary engine on a dyno is different from a motor moving and the oil sloshing up into the crank.
#1338707
01/22/13 10:40 PM
01/22/13 10:40 PM
Winchester 73
Winchester73, I am interested in your rocker arms,I have looked at some on here but have not pulled the trigger . I have a couple of small solid lifter cams I want to try in this later. I'll be in touch. Keith
sorry it took so long to get back on- dont dare buy any.REALLY no body wants mine.ive got a full set ov good rockers and a set minus one of some really hi po p-rods(7/16" thick and light)and a full set of stocker 273 rods.mix and match big on intake small on exhaust or get a replacement to fix the good set
ide try running these on a hyrd cam first-ive alwaye heard adj rockers make power even not on a solid cam becose the lash is better?
[Re: cudadoug]
#1338710
01/23/13 07:10 PM
01/23/13 07:10 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Quote: "I will tell you now that it's at 365 hp and 402 lbs-ft with a cam and intake change."
I'll bite: Change to WHAT cam and intake??
I'm testing a few cams for Mopar Muscle in it. The one in it when I wrote that statement was a Comp Cams Thumper. I also had a Torker2 intake on it then. Keith
[Re: Winchester 73]
#1338712
02/03/13 03:03 PM
02/03/13 03:03 PM
Posts: 20 Colorado
Dirt Slinger
Colorado
Any updates?
Very interested building a 9-1 500cfm 4412 engine per our rules (IMCA Northern Sport Mod). Like to see a intake comparison (stealth, victor jr. and X-celerater). Need to make about 400hp 360ci plus over bore NO head porting.
