Pertronix and factory tach....compatable?? #1338631
11/20/12 09:56 PM
11/20/12 09:56 PM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Good friend has a nice 70 Cuda 340 car that he has restored and has installed an aftermarket electronic ignition (maybe Crane). It uses all original external stuff, except it has two wires leading out of the distributor. Anyway, the car runs great, but the factory tach (ralley dash)doesn't work. Seems I remember issues with compatability, anyone know?
jess
Yeah, it's hopped up to over 160...
Re: Pertronix and factory tach....compatable?? [Re: jt4406] #1338632
11/21/12 12:57 AM
11/21/12 12:57 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
I had the same problem and found info on the net that worked.
Hook the tach into the (-) side of the coil and install a 11.5K 1/2 watt resistor (from radio shack) between tach and coil. The write-up said if that resistor does not make it work to try a 10k, 9k, and 7.5k.
One should make it work.
