Re: Hemi Cuda Progress
[Re: go green]
#1338181
12/31/12 07:00 AM
12/31/12 07:00 AM
Posts: 912 London, England
mopar_mark
London, England
Thanks for the kind comments Not sure on HP, I'm guessing around 1,800 - 2,000hp I had the opposite with the alternator, my Power master lasted 2-3 months on the blown motor, I switched to the MSD and no issues, that being said, I haven't tried it on the new combo.
[Re: smokinwoody]
#1338183
12/31/12 02:22 PM
12/31/12 02:22 PM
Posts: 1,532 off the grid
340B5
off the grid
'bout time you posted again. Looks good! Maybe someday we could have a video. Enjoy the build; gettin' there is half the fun.
Yeah, it's got a smallblock.
[Re: mopar_mark]
#1338186
01/08/13 01:19 PM
01/08/13 01:19 PM
Posts: 2,730 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I love that type of overhead switch panel, but there is a problem. If the throttle hangs wide open (like happened to me last year, and a girl at the track with an Avenger) you have to be able to kill the ignition in the blick of a eye without looking. Things are going to be happening very fast at that point. You need a toggle switch. Something you can bat at and never miss. Maybe you could use a Lokar in car cut-off. (You would like one anyway.) I was lucky, no damage. The girl totaled the Avenger and spent 6 months having operations to put her back together. Her husband bought her another Avenger and she will be racing soon.
2011 Drag Pak Challenger
[Re: rickseeman]
#1338187
01/26/13 06:02 PM
01/26/13 06:02 PM
mopar_mark
London, England
Gradually working through the extensive list of jobs Made up new front n rear polycarbonate screens, not screwed in, as it makes access easier at the moment. Plumbed 80% of Intercooler to Ice box, progress halted due to waiting for fittings, but these arrived this week, so thats the job for tomorrow or tonight if I get off the PC. My excuse is that I am letting my dinner go down Dropped of trans to Frosty last week. As good as old box was, it wasn't up to handling more hp on a regular basis. Basically upgraded shafts n gears, along with changing Convertor stator n bits & pieces . . . When I dropped the box off to Frosty. Andy was also kind enough to donate a Tial BOV which he was no longer using :tup: Finished off coil mounting brackets today, a lot of work for something that doesn't really do anything New fuel pump belt arrived, so now fitted, along with completing the Oil pump to filter oil pipe. Finally got round to removing exhaust/headers, added another bung (Thanks for welding Paul), as I intend to run Lambda's & dropped off exhaust for coating on Friday. Should be done in 2 weeks. Still waiting on a few fuel fittings, but shipment delayed, as waiting for rear wheels to be despatched. Not holding up me up, as there always seems to be plenty to do
[Re: rickseeman]
#1338188
01/26/13 06:04 PM
01/26/13 06:04 PM
mopar_mark
London, England
Rick, Thanks for the advice.
I have an in car cable connected to the rear kill switch, for when that day arrives
[Re: Troy]
#1338192
02/27/13 11:00 PM
02/27/13 11:00 PM
Posts: 12,132 Cleveland
sunroofgtx
Cleveland
Mark, got the message. You will love our coil packs. Those are the same we are petitioning NHRA to allow for Fuel cars. Already allowed in Sportsman and ProMod. We'll get there. Just makes more sense. I'll turn you wires around almost immediately. I have the same heads and covers, but unfortunately up in Michigan. I believe we will need different tubes and hats, correct? Before you send them, can you trial-fit the assembly to try to see if they will even reach the spark plug? Here are my covers. Had some bling put on. Here are the specs on my heads. 2.25 /1.90 ss Manley valves severe duty, Manley 10 degree Titanium retainers,locks, teflon seals.K Motion valve springs( silicon)K1100 valve springs up to .680 lift,fully CNC milled, 170 cc chambers,flow was 454 @.700 lift intake and 322 for the exhaust at .700 lift. per Eric Hansen.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: Chris'sBarracuda]
#1338196
02/28/13 11:37 AM
02/28/13 11:37 AM
mopar_mark
London, England
A small update... I have completed a few my task om my 'To Do' list, but not worth photos, such as fuel lines, suspension sliding link re installed, etc, etc. Made new mounting panel & mounted EFI bits n pieces Also made new Dash frame, still to recieve a bit of paint Gearbox upgrade parts should arrive tomorrow, so will be getting them up to Frosty as soon as I can.
[Re: mopar_mark]
#1338197
02/28/13 02:01 PM
02/28/13 02:01 PM
Posts: 4,634 Motor City
6PKRTSE
Motor City
One sweet machine.....Way further along then mine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
