Re: Oil viscosity choice for strip and street [Re: moparguy7074] #1338018
11/20/12 04:47 PM
11/20/12 04:47 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Brad, would you know if the RP 5w-30 falls into the same category as M1?
Honestly, I don't pay any attention to Royal Purple or Lucas Oil products since I have no interest in using either brand.
Re: Oil viscosity choice for strip and street [Re: BradH] #1338019
11/20/12 06:05 PM
11/20/12 06:05 PM
Sydney,Australia
tex013 Online content OP
tex013  Online Content OP
Sydney,Australia
Brad ,everyone
thanks for the replies and feedback.
this saturday will probly be my last meeting till February,except possibly T&T.
i will run the 20/50 and over Xmas dyno the motor back to back with the 10/40 .
i guess my biggest worry is daily driving/highway use particularly when hot.the last 2 weekend of racing temp has been high 20's and into the 30's Celcius.and its not summer yet.
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Oil viscosity choice for strip and street [Re: tex013] #1338020
11/20/12 06:31 PM
11/20/12 06:31 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
At home and at work I've been using
shell rotella 15/40 HD diesel oil in everything for about 30 years and never had an oil related failure. In the winter around here I switch to 5/30.Dave
Re: Oil viscosity choice for strip and street [Re: BradH] #1338021
11/20/12 08:12 PM
11/20/12 08:12 PM
Az
Crizila Offline
Crizila  Offline
Az
I'll rephrase that and point out that it's not just M1; all the standard light-viscosity (5w30 and under) passenger car oils out today have been "watered down" w/ respect to their anti-wear additive packages that can mess w/ the cat converters. The stuff on the shelf of the local parts store these days is intended for my Honda mini-van, not a 700 HP street car.
It sounds like you've had good luck w/ what you've done to date. Just be aware the latest API standards have applied yet another "hit" to passenger car oils in the name of the saving the environment.
As usual, this thread has gone slightly off target. The OP is presently using a race oil, designed for race engine applications. The point is that in the past race oils usually included high viscosity oils, like 20/50 stuff. Todays race only oils are a lot better than they were 20 years ago and there is less "linkage" between "thick oils" and "race oils" than in the past. As an old conservative engine builder and racer, I have turned the page on this one - and aint lookin back!
Fastest 300
Re: Oil viscosity choice for strip and street [Re: tex013] #1338022
11/20/12 08:29 PM
11/20/12 08:29 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Looks like Joe Gibbs would recommend a 0-20W or 5-20W racing oil
Re: Oil viscosity choice for strip and street [Re: moparguy7074] #1338023
11/26/12 02:00 AM
11/26/12 02:00 AM
Texas
U
UOP Offline
UOP  Offline
U
Texas
Rotella T6 5w-40 here, run it in every vehicle I own. I like the viscosity range, but it doesn't hurt that it's a full synthetic for only $6.49/qt($27.95/gal). The only downside is that most stores don't carry it in quarts so they have to be special ordered (I use Oreilly), but I usually just keep a few gal jugs around.
Re: Oil viscosity choice for strip and street [Re: tex013] #1338024
11/26/12 11:37 AM
11/26/12 11:37 AM
gregsdart Offline
gregsdart  Offline
Recommended oil way back in the day was 10w30 for flat tappet motors. About half the reason IMHO that we run thicker oils in our race motors is to cover up little problems like sucking a little air on launch in the oil pan, losing oil pressure during decel, etc. A lot of times it is such short duration that I don't think it registers on the gauge. But aerated oil is still a problem and the thinner it is the quicker the bearings will get hurt. I chose to play it safe and run 20w50 because of those potential problems. The last problem I had was a sheared off oil pump drive in the middle of a pass. At the lights going 152 mph and turning 7400 rpm, the gauge read zero. With a Torqueflite you have no choice but to leave it in gear and let the motor run all the way till you stop. The rod bearings were a tad ugly, but not to a point that they would fail soon. The mains looked great and were not replaced. I really like that Brad Penn 20w50
Re: Oil viscosity choice for strip and street [Re: tex013] #1338025
11/26/12 02:56 PM
11/26/12 02:56 PM
Brad ,everyone
Tex
Tex, I use Valvoline 5W20wt non synthetic in my Duster, limited street and a lot of strip My bearing clearances are pretty loose, .0035+ on the rods and mains , My oil pressure reads right at 20 lbs at 850 RPM in gear with oil temps at or above 180F on the street 1200 RPM makes the oil pressure go up to 35 lbs and it has 50 lbs at 1500 RPM, 65 lbs at 7000 RPM There is some HP gains with low oil temps with the lightweight oils is what I found years ago, just what most bracket racers need
Re: Oil viscosity choice for strip and street [Re: Cab_Burge] #1338026
11/26/12 06:05 PM
11/26/12 06:05 PM
Sydney,Australia
Sydney,Australia
UOP,Cab ,Greg
thanks for all replies.
much to ponder.
Greg i turn around 6300-6400 through the traps and have a deep sump.hopefully that should stop aeration etc on launch.
Cab i drive the car every day so we will see with the 10-40.a few more hp won't hurt
by the way it was in the 90's on saturday at the races
thanks all
Tex
New best MPH 130.32
Re: Oil viscosity choice for strip and street [Re: tex013] #1338027
11/26/12 06:18 PM
11/26/12 06:18 PM
I probally should state the HP gain versus losses results on thin multiweight oil versus straight wt. oils are based on a dyno tests that I did years ago. I was dyno testing the first motor I built for a customer who wanted it dyno tested and tuned, it was 1962 Dodge 390 HP 413 M.W. I broke the motor in on straight 30 WT Valvoline non detergent oil and then switched it to detergent 30 WT Valvoline, I was seeing a 10 HP gain on oil temps between 130F versus 160F + the hotter I got the oil temps(up to 190 F, no gains seen after that hot) before starting the pull the more HP it would make I later switch on other motors to using Valvoline 10W30WT multi grade and then to 5W30 and finally at 5W20WT, I saw no HP or torque gains based on oil temps on the lighter weight multi viscosity oils All the motors I tried doing pulls at 120 F with multi weight oils versus at or above 160F with the same motor and oil saw no measurable HP or torque gains
For you bracket racers that see your cars pickup when hot lapping, what type and weights of oil do you use
Re: Oil viscosity choice for strip and street [Re: Cab_Burge] #1338028
11/26/12 07:04 PM
11/26/12 07:04 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
"you bracket racers that see your cars pickup when hot lapping, what type and weights of oil do you use"
Yes my car will pick up but I do not think it is oil temps. You have trans temps- rear end -wheel bearing-motor get heat in it and burns fuel better. I run 15-40 wt oil. all these things together make it pick up.
Re: Oil viscosity choice for strip and street [Re: VernMotor] #1338029
11/27/12 01:12 AM
11/27/12 01:12 AM
Sydney,Australia
Sydney,Australia
thanks Vern,
i know what you mean re all things adding up.i'm licky i get a good heat soak/cycle driving out to the track
Tex
New best MPH 130.32
Re: Oil viscosity choice for strip and street [Re: VernMotor] #1338030
11/27/12 01:42 AM
11/27/12 01:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My first pass of the day is always a bit slower...
thats with driving it around to warm it up
Re: Oil viscosity choice for strip and street [Re: MR_P_BODY] #1338031
11/27/12 04:12 PM
11/27/12 04:12 PM
I try to drive my car around enough before racing it at the track to get the oil and trans. temps. up to at least 130F, I run 75-90 WT gear oil in the rear and I do not have a temp. gauge in it so I don't have any idea what it runs at My car does not vary more than .02 on the ET from first run to last run, early morning to late afternoon,(unless the track is bad)5W20Wt motor oil
Re: Oil viscosity choice for strip and street [Re: Cab_Burge] #1338032
11/27/12 05:51 PM
11/27/12 05:51 PM
Sydney,Australia
Sydney,Australia
MrP,
my first pass is often the slowest - must need to blow the cobwebs out
Cab,i wish my spread was so tight though with the 825 md it does seem more sensitive to da change.may have to go back to the prosystems hp1000 based carb
Tex
New best MPH 130.32
Re: Oil viscosity choice for strip and street [Re: tex013] #1338033
11/27/12 09:36 PM
11/27/12 09:36 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
My car will be a little slow first pass. I do drive it around and warm it. but not allot. because the first 3 rounds of racing there will be down time. about a hour in between.. Till you get to later rounds .. so I want to know what my runs after it sets for a hour. I suppose you could drive it around before you go up for ever round but that would be a pain. I know if my car set for less then a 1/2 hour I need to take a little off the dial for that..so many things come in to play to dial the car..Now that I run e-85 the weather does not change it much. but still need to watch temp of car and track and wind LOL
